wwhat to build
quick 52
wwhat to build
what is the prefer ci for the street on pump gas... I want to use a stock block and A429 heads tell me the rest...
quick 52- Posts : 612
Re: wwhat to build
545 or so..........
Re: wwhat to build
What Fabio said.......
Re: wwhat to build
Thanks lot of info..
Re: wwhat to build
Whats you budget?
what are you going to use it for?
what parts do you already have?
Re: wwhat to build
all you got was what you asked for.
Re: wwhat to build
quick 52 wrote:Thanks lot of info..
Tell us how much you can spend, and how fast you want to go.
Curt- Posts : 2791
Re: wwhat to build
richter69 wrote:all you got was what you asked for.
cletus66- Posts : 865
Re: wwhat to build
I got a 86 truck block and the A429 heads victor and 950 proform... would like 600 rwhp vehicle is a 52 f1 weights is 3870 with driver have a 3.89 with 4500 stall 700r4 might change to 400 with GV that I have... the 700 is not the strongest trans out but iitbeen doing the job for a while
Re: wwhat to build
quick 52 wrote: I got a 86 truck block and the A429 heads victor and 950 proform... would like 600 rwhp vehicle is a 52 f1 weights is 3870 with driver have a 3.89 with 4500 stall 700r4 might change to 400 with GV that I have... the 700 is not the strongest trans out but iitbeen doing the job for a while
Dale are you ready to cage that thing then? 600rwhp would probly be 750hp (or so) at the flywheel. That'll get you in the 10's on motor .
Re: wwhat to build
well 750hp is more than I need or want maybe 745hp... really I want around 600hp should be good want it to run on pump gas and 10.80 on motor would be coolbigblockfox468 wrote:quick 52 wrote: I got a 86 truck block and the A429 heads victor and 950 proform... would like 600 rwhp vehicle is a 52 f1 weights is 3870 with driver have a 3.89 with 4500 stall 700r4 might change to 400 with GV that I have... the 700 is not the strongest trans out but iitbeen doing the job for a while
Re: wwhat to build
545-557
Port your heads and intake to the max
10.5-11:1 compression (lower if your not good at tuning)
TFS Mafia Intake and a 1250
2 1/4 headers and a 3-4" exhaust
Street Solid Roller and Isky or Crower Lifters Keep the lash tight.
Crower or Comp Steel Rockers
Balance of valve train to match the cam
Good oil system, Need a good deep pan with baffles and a tray.
Kaase Oil Pump
SFI Balancer
Kaase Oil Pump
SFI Balancer
Re: wwhat to build
dfree383 wrote:545-557
Kaase Oil Pump
SFI Balancer
thank you that seem pretty stout to run 10.80
Re: wwhat to build
your moving 3900lbs...... Ain't going to get there with a grocery getter build.quick 52 wrote:dfree383 wrote:545-557
Kaase Oil Pump
SFI Balancer
Re: wwhat to build
git Er dun
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
» 460 build w/p51 heads build HELP!!
