front motor plate
front motor plate
I have an 86 bronco. i have swap out the twin d44 to straight d44 and anyone run into a problem with the steering box getting in the way of front motor plate... i putting in a 460 into the bronco. please help
pigs521bbf- Posts : 173
Re: front motor plate
i dont know what your set up looks like but Keith Fulp can make you any size plate you need. https://www.429-460.com/t16642-bbf-mid-plate-for-truck-pullers-mud-and-sand-racers
i am trying to move motor back a couple of inches for weight transfer.. and i have notice the power steering box was getting in the way..
I'm using a plate that I got from Randy Malik in my 89 chassis. I cannot say that it would clear the steering gear, but some kind of cutting and fabrication should get the problem solved. I prefer the steel plate, because I could do anything to it with the tools in my shop. Aluminum is not as easy to weld or cut for me.
schmitty- Posts : 4538
» front motor plate and mid plate
» Front Motor Plate
» What would a front motor plate do for me?
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» BBF 429/460 alum front motor plate.
» Front Motor Plate
