Scat 4340 cranks - what RPM do you turn?
+8
BradB
Barney
bigblok2000ranger
busta
12 posters
Just wondering what sort of RPM you spin your 4340 cranks to. I have a 4.5" here ready to go into a new engine and curious what guys are spinning them to.
busta- Posts : 28
Re: Scat 4340 cranks - what RPM do you turn?
Had my 4.300" to 7800 couple times in my 523 expiementing with shift points. 7400 was best with that deal for me.
My 4.300 when it was a 528 7500, its in a 572 and will be seeing 7200ish in the next build.
4.3, been 7900 a time or two, goes 7600 on a regular basis.
rpm would matter more about the valvetrain than the crank IMO
To answer your ?.imo a Scat 4340 will be fine in the mid 7k range for quite a few passes,but anything higher than that (8k or higher) for a substantial duration,I would go a custom billet piece.jmo
8000+ rpm, pulling truck app. Not sayin its wise but its done on a regular basis. Hell, we were going 7500-8000 with the cast scats. Ya do what ya can with what ya got sometimes even if It's risky.
BradB- Posts : 43
we shift our 3" stroke deal at 8400, its been over 9000 a few times......
Been 6900 bouncing off the limiter with a 4.5"
John Myrick- BBF CONTRIBUTOR
BradB wrote:8000+ rpm, pulling truck app. Not sayin its wise but its done on a regular basis. Hell, we were going 7500-8000 with the cast scats. Ya do what ya can with what ya got sometimes even if It's risky.
The truck pull guys are king when it comes to the rpm thing
A short stroke BBF 4340 crank wont be your problem when turning high rpm, but everything tied to it may be suspect...............
Mine has a 4.5" crank, 7200 R.P.M at the finish line.
hienergy557- Posts : 179
we spin 8700-9300 but the bottle will do that!
with a 2200 gr bobweight
Frank Merkl- Posts : 1524
» Scat/Lunati cranks
» Eagle 4340 Cranks
» IDT Block & Scat 4340 crank ?
» NEW Scat 4.500 4340 crank w/boss snout
» SCAT / ADNEY BROWN 4.5 4340 CRANK
» Eagle 4340 Cranks
