IDT Block & Scat 4340 crank ?
Henryslx
Copperhead
On my new build, I was planning on doing a high compression, A460 headed, 4.60 bore / 4.50 stroke in an A-460 block in conjunction with a Scat forged 4340 crank.
My question is, I have the oppurtunity to purchase an Eliminator block at a considerable discount and I was wondering if it would be a bad move to put a Scat crank in such a good block?
Keep in mind, I'm probably looking at somewhere around the 1100hp mark when everything is said & done. I know the block is way, way over-kill for what I need, but the extra $$ isn't all "that" much. I just don't want my build to turn into something so costly that I'm 2 years in the making having to come up with the $$ to finish it.
The main thing that has me leaning toward the IDT block is (other than the decent deal I happened upon) that I could bore it 4.625 (and make it a 605) and have plenty left (unlike "most" A-460 blocks),..... as well as having 4-bolt caps on all five, not just the center three.
What the general concensous?
Copperhead- Posts : 492
Re: IDT Block & Scat 4340 crank ?
Sounds like a good plan to me.
Curt- Posts : 2791
Ive got a eliminator block and jus bought a Scat crank from Adney....Thats the only one i could find unless u want a BILLET ....Im sure theres other stuff out there tho....Good luck. Henry
Henryslx- Posts : 89
nuthin worng with that combo..............
If the Price is right..... Coooooommmmmeee on Down !!!!
the scat crank should be up to it.
there are guys making 2000 hp on them cranks -billet isnt always better
Scat 4340 (From Adney) FTW!
D. Sea- Posts : 2768
» SCAT / ADNEY BROWN 4.5 4340 CRANK
» Eagle 4340 crank
» Scat 4340 cranks - what RPM do you turn?
» 4340 eagle crank
» Scat Forged 4340 Crankshaft, 4.50 stroke - SOLD
» Eagle 4340 crank
» 4340 eagle crank
