Rocker arm stud bolt ?
Rocker arm stud bolt ? Empty Rocker arm stud bolt ?
Post  whitefield April 17th 2013, 11:34 am
What sealant or loc tite do you use on the rocker stud and what are the torque specs. ? Thanks
whitefield
whitefield
Rocker arm stud bolt ? Empty Re: Rocker arm stud bolt ?
Post  69F100 April 17th 2013, 11:50 am
whitefield wrote:What sealant or loc tite do you use on the rocker stud and what are the torque specs. ? Thanks
I use the red loctite on iron blue on aluminum I just tighten mine as tight as I can get them with a regular 3/8 rachet never had one to back out
Post  Lem Evans April 17th 2013, 11:57 am
Alumimium or iron head?
Post  whitefield April 17th 2013, 11:58 am
Lem Evans wrote:Alumimium or iron head?
Iron Head
whitefield
whitefield
Post  IDT-572 April 17th 2013, 12:06 pm
Red on cast iron or green but be carefull with green you may have to heat it to remove later.
Post  rmcomprandy April 17th 2013, 12:24 pm
Torque =
70 lbs. with an iron head
55 lbs. with an aluminum head without heli-coils.
