ladder bars or 4 link??
FORDMUD
pigs521bbf
Which is better for mud racing.. i am trying to pick ladder bar or 4 link for my 9 in rear end on my 86 bronco.. please help..
any good kits from summit or jegs??
pigs521bbf- Posts : 173
Re: ladder bars or 4 link??
Class rules usually dictate. 4 link is a whole lot more adjustable. And probably easier
FORDMUD- Posts : 290
If there is no restriction, 4 link all the way. My bronco had a Chris Alston kit and it worked great, if you are going to do it, don't skimp on the rod ends. I had one crack, fortunately I found it on the trailer, not during a pass.
prosandguy- Posts : 186
Definitely check the rules where you race. It wouldn't be too much fun to get bumped into a class your not prepared for. My class allows for ladder bars but not a 4 link.
68formalGT- Posts : 865
does any one have part numbers for ladder bas or 4 links? i dont wanna spend too much $
http://www.cachassisworks.com/c-401-4-link-packages.aspx
some options for ya, not for the faint of heart, lotta cutting/welding and 2x measuring to get it right.
I did a 4link on my 89 chassis and I wouldn't do anything else on a strictly competition vehicle. I had a custom set of frame brackets made that bolted in place of the front spring mount. No 4 link is going to be cheap, but neither is a ladder bar setup if you put good double adjustable coilovers with it. You are going to spend at least $1k to do it right, and maybe more depending on how you do it.
schmitty- Posts : 4538
My next set up will be a 4 link.
crittersf1- Posts : 521
» ladder bars vs 4 link
» Ladder bar question
» ? about ladder bars
» Cones, Collectors, Ladder Bars
» Ladder Bars
» Ladder Bars
