piston question with cj head
will these piston work with factory cj heads
http://www.summitracing.com/parts/PBP-10661-060/
johndickjr- Posts : 896
Re: piston question with cj head
Those pistons are for all factory valve layout heads, like the DOOE-R heads. They are for a 3.85 stroke with a factory 6.605" rod. How big of a cam are you running? There is no exhaust relief, and with larger cams, there may be an issue with piston to valve clearance.
schmitty- Posts : 4538
motor is already together, guy im helping just wants some better heads, cam is a hydraulic c460 cam, what all other head will work ?schmitty wrote:Those pistons are for all factory valve layout heads, like the DOOE-R heads. They are for a 3.85 stroke with a factory 6.605" rod. How big of a cam are you running? There is no exhaust relief, and with larger cams, there may be an issue with piston to valve clearance.
A429 Ford Motorsport, Blue Thunder CJ, TFS Streets and Edelbrock RPM stuff will work with those pistons if your looking for aftermarket aluminum ones. They will also work with all factory iron heads.
» A head piston question
» Head/piston question
» Piston and Head ?
» What head for piston
» piston question
» Piston and Head ?
» piston question
