piston question
piston question
i have 460 with c9ve heads lw2602 flat tops with 1 valve relief is the relief cut for the ex valve or intake valve cam size 543L 574ex thanks guys
74f100- Posts : 28
Re: piston question
Generally Big Block Fords only require an intake valve relief.
If your pistons only have one its for the intake.
Re: piston question
thanks man got short block together was throwing me off because #s on pistons are up side done when in the hole put thats where it needs to be for the intake valve thanks
74f100- Posts : 28
» Piston Question
» Piston question
» piston question
» The question of the day piston ring
» Head/piston question
» Piston question
» piston question
