Piston question
Piston question Empty Piston question
Post  Fordman September 4th 2011, 1:20 pm
Ok here is the deal. I'm having a 545 built using Eagle crank, rods, and JE pistons. The first machine shop was taking way too long, so I picked everything up last Wednesday. He bored the block, milled the heads, fly-cut the pistons, and started to balance the crank. Anyway, when he fly-cut the pistons, he broke into the first ring groove on the top side only. My builder now is saying that he doesn't like it, but it should be fine as long as I don't run it too lean. So has anyone experienced this before? If so should I be worried? I don't want to buy another set of pistons, but I will. Thanks in advance...
A460 block
TFS A460 heads
Fordman
Piston question Empty Re: Piston question
Post  rmcomprandy September 4th 2011, 3:20 pm
All the time ... usually on a Big Block Chevy notch or A460 notch.
Now you have one major gas port.
Post  Fordman September 4th 2011, 4:27 pm
So, do you think I should use the pistons I have or replace them?
Fordman
Post  ribald1 September 4th 2011, 7:41 pm
Do you need a cut near that deep?
How much piston thickness exists under the cut?
When he 'started' to balance the crank did he cut into the counterweights based on the pistons you have?
It is not optimal, but first you have to figure out if if you are the pig or the chicken in this ham and egg breakfast.
ribald1
Post  DanH September 5th 2011, 2:36 pm
ribald1 wrote:Do you need a cut near that deep?
pig or chicken , way I see it , doesnt matter ; your butt is cooked .
DanH
Post  rmcomprandy September 5th 2011, 4:12 pm
Fordman wrote:So, do you think I should use the pistons I have or replace them?
Unless you run it lean or have to much ignition timing or detonate it ... don't worry about it.
