piston question
piston question
Do they make a tool to cut valve reliefs in pistons or do I need to take them back to machine shop? I had the pistons cut so they would be at zero deck & know I have zero clearance on exhaust valve. The intake relief is much deeper & is fine.
mustangjeff- Posts : 87
Re: piston question
Isky makes one I think John Kaase also has one on his sight....
the Coug- Posts : 3055
Re: piston question
Do you think I could do it with pistons in engine if I used a shop vac while I was cutting?
Re: piston question
yes bring the piston TDC and put grease around the piston and put cutter in the head and cut just make sure you cut slowly and make sure you know how deep you are going.... try to make each the same.... after lower the piston slowly and wipe the grease. should be ok....
» Piston Question
» piston question
» Piston question
» Piston question for stroker.
» piston question with cj head
» piston question
» Piston question
