Piston Question
Piston Question Empty Piston Question
Post  Rich Osmond March 6th 2013, 4:25 pm
All - Hopefully a straight forward question for the experts on here. I recently bought a 532 A-head engine only to discover the block had several cranks through the main cap bolts holes (bummer...). Anyway, I am building an entire new short block for the A-heads and would like to reuse the rotating assembly out of the cracked block in another block utilizing Eddy CJ heads.
Question - Is this as simple as checking piston to valve clearance and having a new relief (or reliefs) cut? The parts are nice and hate to see them go to waste if I can use them. Thanks for your help!!
Rich Osmond
Piston Question Empty Re: Piston Question
Post  bbf-falcon March 6th 2013, 4:54 pm
If the pistons are FLAT tops I cant see why not as long as the correct size reliefs are cut and checked before assembly.
Post  Rich Osmond March 6th 2013, 4:56 pm
Yes, should have mentioned they are flat gas ported Diamond pistons with a single (intake) valve relief. Thanks!
Rich Osmond
Post  Lem Evans March 6th 2013, 4:58 pm
What comp ratio are you looking for? Flats w/A460 heads may not have much.
Post  Rich Osmond March 6th 2013, 5:04 pm
Nothing too high as I will run it on E85 and street drive it. I may have calculated it wrong but came up with ~ 12.6:1 estimating a second valve relief of ~3cc's, .005" down in the hole and a .040" gasket thickness. Lower would actually be better.
Rich Osmond
Post  bbf-falcon March 6th 2013, 6:20 pm
Rich Osmond wrote:Nothing too high as I will run it on E85 and street drive it. I may have calculated it wrong but came up with ~ 12.6:1 estimating a second valve relief of ~3cc's, .005" down in the hole and a .040" gasket thickness. Lower would actually be better.
I would say you are fairly close.
