Powerglide gears
Powerglide gears Empty Powerglide gears
Post  69F100 April 25th 2013, 6:22 pm
Which is the best gear ratio to run in a pg behind a552 around 700 hp truck is around 3100 with driver with 4.30 gears.
Powerglide gears Empty Re: Powerglide gears
Post  whatbumper April 25th 2013, 8:02 pm
Stick with 1.80. Change rear gears if a gear change is required. Much cheaper.
Post  69F100 April 25th 2013, 8:08 pm
the trans is not built yet i not sure what gears is in it it came out of a 66 chevy with a 6 banger it is the short tailshaft just wondering what gears would be the best as i start collecting parts for the build and oh ya it is a n/a engine not spray or anything
Post  whatbumper April 25th 2013, 8:27 pm
It probably has a 1.82 set. Don't use those. I can sell you a new mid range priced set if needed. And any other trans parts.
Post  cool40 April 25th 2013, 11:05 pm
x2 dont use the 1.82 gear.a new 1.76{stock} may last a while but a good 1.80 would be best IMO.
Post  69F100 April 26th 2013, 12:48 pm
are they some number on the trans that tells you what gears are in it
