BPO Powerglide
jts557
BIGDOG466
racerk_2000
BPO Powerglide
Does anyone know what gear ratio a Buick Pontiac Olds powerglide would be? I have located one and if I was going to use it I would have to cut the Bellhousing off anyway. Does it follow the same rules as the chevy glide, 6 cyl is probably a 1.82 and v8 most likely being a 1.76?
Kevin
Still Stuck In Iraq, Now In Tall'Afar
Kevin
racerk_2000- Posts : 88
Re: BPO Powerglide
yes thats pretty much std gears setup. the BOP should be worth alittle more to the BOP guy's but thats just my oppinion....
the Coug- Posts : 3055
Re: BPO Powerglide
racerk_2000 wrote:Does anyone know what gear ratio a Buick Pontiac Olds powerglide would be? I have located one and if I was going to use it I would have to cut the Bellhousing off anyway. Does it follow the same rules as the chevy glide, 6 cyl is probably a 1.82 and v8 most likely being a 1.76?
Kevin
You should put in a straight cut set if you going to put it behind a BBF
BIGDOG466- Posts : 265
Re: BPO Powerglide
Do I need to go to aftermarket gears for a Big Block. It is a 466 with p-51's i hope to make about 700 HP.
Re: BPO Powerglide
All pg are 1.76 1.82 1.96 mail jeep but there are tons of aftermarket sets .I twisted a tci superset at the
splines with a mild 530 spend the money and go 1.80 straight cut and never have a problem .
i have tried different low gears never could notice a difference between a 1.76 and 1.96 sorry but my
expierence ?
expierence ?
jts557- Posts : 56
Re: BPO Powerglide
The OEM type 1.76 will handle a 700hp engine fine, infact they can handle a bunch more as long as they are in unabused condition or new.
Re: BPO Powerglide
dfree383 wrote:The OEM type 1.76 will handle a 700hp engine fine, infact they can handle a bunch more as long as they are in unabused condition or new.
agree. ran one in a nitrous sbf car at 3300lbs for a couple years. ran mid 5's 1/8 mile low 1.20's 60ft.
^^about 780ft/lbs of torque for you sb haters
whatbumper- Posts : 3024
Re: BPO Powerglide
All are 1.82 or 1.76. A 1.96 set never came OEM in any Glide, ever. There are a couple ways to determine what gearset is in an OEM Glide. You can measure output shaft diameter, or snug up the band and then rotate the input shaft and see how many turns it takes to move the output shaft one turn. The 1.82 sets are fine for mild performance applications but I'd never really recommend them for anything making real power or using a transbrake. The 1.76 sets will withstand decent power. Usually I advise they'll take 750-ish or a bit more. The gears themselves will usually fail first. I've also seen output shafts snap off the flange. The 1.80 sets are a good choice for strength and cost is reasonable at well under $800. The ones I have at that price area also have a good warranty if the highly unlikely occurs.
Oldani- Posts : 46
Re: BPO Powerglide
I have a couple goofy looking gear sets i thought were from a mail jeep and they were 1.96??
I guess i should have looked at the ratio before believing what i was told .They sure dont look
strong.
strong.
jts557- Posts : 56
Re: BPO Powerglide
Most likely they're 1.82 sets if in a stamped carrier.
Only other weird Glide sets out there are some coarse spline ones from trucks and they had a shorter tailshaft/tailhousing than normal. And I wish I could find the pics I have of some others that must have 3' long tailshafts, lol. They have some laying around at BTE and are not sure what they came in originally. Very strange gearsets!
Oldani- Posts : 46
Re: BPO Powerglide
I have a TCI 1.89 super set. Not really sure how super. What do you think Steve?
Curt- Posts : 2791
Re: BPO Powerglide
The helical 9310 steel gearsets were all that you used to be able to get. Then they came out with the Vasco helicals. Then the 9310 straight cut sets. And some Vasco stuff too. The helical Super Sets will stand up to a reasonable amount of power. The only bad thing is that they use a smaller gear size to attain that ratio. I'd say for maybe a light car up to 2500 lbs or so they'd handle quite a bit of power. More weight makes them a bit marginal. But, they should handle 800 or so. Anymore the straight cut sets are the best way to go though.
Oldani- Posts : 46
Re: BPO Powerglide
I understand. It was in a transmission that I gave away because someone wanted a stock case. We bought it as a backup to run them in a s/g car, but now all my stuff is short. Maybe someone on here needs a good set for a light car. Thanks Steve.
Curt- Posts : 2791
