Powerglide ?
Powerglide ?
Which line is return on a pg just want to make sure I hook them to my cooler right it has a oneway valve in it dont want blow the lines off. I done that before it make a mess.
Re: Powerglide ?
top i think.........fabio will tell me if i'm wrong
Re: Powerglide ?
top return bottom pressure
Re: Powerglide ?
so whats with the one way valve?
Re: Powerglide ?
Not sure it is the factory 2000 ford ranger trans cooler when I put the c6 in it it blew the rubber line off. I blew air thru it it would only go thru one way
Thank I going hook the lines up tomorrow going monday to have the drive shaft built .
Re: Powerglide ?
My B&M Pro Ratchet will work with the pg all I had to do is move the low gear pin to the other hole and remove the pin for park to turn it into a 2 speed shifter. That save me buying a new shifter I have the right bracket for the shifter cable or at least it is the same as the one Rick has on his. I going to build a bracket for the cable Monday at work that way I can mig together to get the angle right for the cable.
