A460 valve ??
56Tbird
A460 valve ??
Can you run a 2.40 intake valve in a Ford Motorsport A460 head with a 4.440 bore??
56Tbird- BBF CONTRIBUTOR
Re: A460 valve ??
56Tbird wrote:Can you run a 2.40 intake valve in a Ford Motorsport A460 head with a 4.440 bore??
Yes, but it aint the preferred way to go.
A little work at the top of the bore would help matters.
Re: A460 valve ??
A small notch I guess is what your referring to?
Re: A460 valve ??
56Tbird wrote:A small notch I guess is what your referring to?
No, no notch required. The exhaust valve is the closest valve to the bore.
Charlie
c.evans- BBF VENDOR SPONSOR
Re: A460 valve ??
What about the valve relief in the piston? Will it be large enough for the 2.40 intake ?
Re: A460 valve ??
56Tbird wrote:What about the valve relief in the piston? Will it be large enough for the 2.40 intake ?
Who's pistions? How big of notch do they have?
Re: A460 valve ??
Dan,
J B B has already called me about this twice this past week, so I assume he's talking about your engine. Is that correct?
Anyway, most likely the valve relief in the piston will not be big enough. As a general rule of thumb, your valve relief should always be +.125" bigger in diameter than your valve head diameter. However, it's no problem to flycut your relief bigger with a piston vice and a Bridgeport. Lawes and I have a piston vice and I know J B B has one too.
Hope this helps,
Charlie
Re: A460 valve ??
Yes,it's my engine. I just thought I'd ask on here before bugging him with any unneeded questions. I know he's busy and hate to cut into his shop time.Thanks for all the info.
Re: A460 valve ??
why the smaller shortblock?
Re: A460 valve ??
Because that's the size of the Piston that he has on hand to use. Kind of a swap meet build,that should produce great power w/heads that he has.
Re: A460 valve ??
those are the best kind of builds lol
Re: A460 valve ??
I been picking up pieces here and there for about 3 years for this thing. I hope it'll get after it,if I ever need it!!Still got a small fortune in it
Re: A460 valve ??
56Tbird wrote:I been picking up pieces here and there for about 3 years for this thing. I hope it'll get after it,if I ever need it!!Still got a small fortune in it
X2 I bought parts as I could for the 552 if I count the heads on it it only took only about a year to get everything and I have some $$$$ in it but not as much if I would have went out and bought everything at once.
» TFS A460 valve springs
» New valve train for OLD TFS A460's.
» question on compression ...using pump gas (a460...using fms a460 heads)
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» Ford Motor Sport A460 Intake Part # M-9424-a460 125.00 shipped
