Rod length
Rod length
Looking to build a 4.5 stroke with a 4.5 bore. what is the best rod length 6.8 or 6.7 ?
racinray- Posts : 22
Re: Rod length
I have 6.8 rods in mine.
Why are you staying with a 4.5 bore?
Re: Rod length
So there are no pro's or con's with either length? Unless someone has a used aftermarket block not willing to just max bore a block.
Re: Rod length
If you use a D9 or A460 block they have almost 1/4" longer cylinders than the C8/C9/D0/D1 blocks, so the .100" shorter rod is not a factor in that case.
» WTB drive shaft for 1989 fox
» Rod length
» 632 cid rod length 6.7 or 6.8
» Connecting rod length theroy......
» pushrod length
» Rod length
» pushrod length
