Inovaters west & MSD crank trigger wheel
Wheelie58
69bluehotrod
Need a bit of input here,
the wheel i.d. is 2.177 about .010 smaller than the balancer witch is 2.187, so the wheel will not slide up on the balancer
( works fine on my fluid dampner ) has anybody else had this issue?
if so how did you fix the problem?
was thinking just get a brake hone and ream it to fit or should I take it to a shop with a lathe & let them take the .010 out...
Re: Inovaters west & MSD crank trigger wheel
Lathe for sure. It is normal to have a mis-match in the balancer register OD/iD and various accessories, requiring machine work or fabricated adapters to center everything up.
There is more than one "BBF" register diameter used by the aftermarket, and other balancers speced with "BBC" fronts ...or mixtures of both.
The IW is a nice piece....
Keith
Keith
Keith, I needed to ask you on the motor plate & pionter that I got from you do I need to mark the Balancer with a "NEW" TDC/0...??? cause the badass little pointer is nowhere nere 0 when the engine is at TDC.
You probably have a 10 O'clock pointer.
Depending on who specified your IW balancer, it probably has an 11 o'clock zero position.
If it comes out above the Danny Bee idler, it is 11. Below the idler it is 10.
I have Danny Bee pointers for either type.
I can just swap it out. Just give me a call.
Keith
678-458-2033
Keith
678-458-2033
That Lem....he has all of those fancy camera crews.
That is an 11 o'clock in the pic.
F.Y.I. all of the I.W. dampers that I've seen have the 11 o'clock t.d.c. Being the same as the stock and FRPP bbf dampers.
No worries...we will get him all fixed up.
By the way Lem...
Even though all of my stuff is 10 O'clock ATI...I like the 11 o clock better for visibilty of the mark.
Plus..The I/W is awful pretty.
Keith
By the way Lem...
Keith
69bluehotrod wrote:Need a bit of input here,
You can call Innovators West and send them your damper so, they can install a crank trigger front cover.
OR, lathe cut the I.D. to the correct size.
yep,i think it was $100 very nice folks to deal with toormcomprandy wrote:69bluehotrod wrote:Need a bit of input here,
Wheelie58 wrote:No worries...we will get him all fixed up.
By the way Lem...
Keith
Got it all worked out with Keith today, sent him the wheel today , he is gonna put his MOJO on it and send me an 11 o'clock pointer so it all good, thanks for the help Keith.
if Keith got you all fixed box the fluid dampner up and send it to me, they are suppose to be junk anyways lol
the Coug- Posts : 3055
I would rather the entire Mustang be shipped here.
It is really looking nice.
Keith
Keith
the Coug wrote:if Keith got you all fixed box the fluid dampner up and send it to me, they are suppose to be junk anyways lol
Coug, its for a long snout crank, if you need it they retail for around $450-460.00 I would take $250.00 for it.
I have the spacer to go with it if you need that also.
Wheelie58 wrote:I would rather the entire Mustang be shipped here.
Keith
Thanks Keith,
shes getting there...
» 36-1 crank trigger wheel
» Crank Trigger Wheel
» aluminum crank pulley and a crank trigger
» Mounting Holley crank trigger wheel
» New BBF Peterson Splined Mandrel & BBF 7-inch MSD Crank trigger wheel
