D3ve head ,
D3ve head ,
What's the best way to get high compression (11.0to1)with this heads ? Mill , angle mill , dome piston ? They will be on a 460 .
boker- Posts : 21
Re: D3ve head ,
Best way to get 11:1 CR is to sell them a get a set of early heads. If you intend to do a bunch of work to them you will find you are better off saving up your pennies and getting a set of aftermarket heads unless you are stuck on the idea of factory iron heads.
466cj- Posts : 391
Re: D3ve head ,
No , I'd love to have a set of after market heads just don't see me comeing up with that kinda money any time soon , I also have a set of dove-c heads but there rough and will need a total rework . Valves, guides ,seats ect
boker- Posts : 21
Re: D3ve head ,
10:1 would be a better goal with a D3VE head which can be done with a flat top, zero deck, and heads cut down to a 92cc chamber volume. To get to 11+ CR really would require a domed piston which are available, but not really the route I'd take.
If that is what you want Speed-Pro Forged Pistons ZL2443NF30 will get you 11.4:1 CR with a 95cc chamber and zero decked.
466cj- Posts : 391
Re: D3ve head ,
Boker, where do you live?
GT300TD- BBF CONTRIBUTOR
Re: D3ve head ,
boker wrote:What's the best way to get high compression (11.0to1)with this heads ? Mill , angle mill , dome piston ? They will be on a 460 .
Are you ever intending to upgrade this same engine again with different heads...?
If not ... go the custom domed piston route.
IF you are going to upgrade this same engine again, (not build a complete new one), then go flat-top pistons and mill the heads .030" or more if you also mill the intake side.
Re: D3ve head ,
rmcomprandy wrote:boker wrote:What's the best way to get high compression (11.0to1)with this heads ? Mill , angle mill , dome piston ? They will be on a 460 .
Why a custom dome when there is one available off the shelf?
466cj- Posts : 391
