D3VE Heads
D3VE Heads
I have what it believed to be a 460 out of a truck. The heads are coded D3VE A2A. The engine runs well but I was told it's not a very desirable engine because it's an emissions type. I'd like to know more about it. What do the date codes tell me. Why are these heads considered useless and does that include the block and why?
If this came out of a truck, would it most likely be 4 bolt mains?
FordNut252- Posts : 2
Re: D3VE Heads
Not useless, not undesirable, not likely 4 bolt main. They are low compression heads with low compression block. Port the heads they are good. Perhaps a thin headgasket, shave the head will raise compression if youd like more, and dont want to open the bottom end. Those changes for compression will change valvetrain geometry.
litshoot- Posts : 102
Re: D3VE Heads
FordNut252 wrote:I have what it believed to be a 460 out of a truck. The heads are coded D3VE A2A. The engine runs well but I was told it's not a very desirable engine because it's an emissions type. I'd like to know more about it. What do the date codes tell me. Why are these heads considered useless and does that include the block and why?
The compression ratio being around 8/1 and the retarded timing set are the only real undesirable traits.
Not 4 bolt, the heads, (the casting codes simply say the heads are 1973 or later), are certainly NOT useless.
» D3ve heads
» Was there any D3VE heads that didn't have the hardened seats??
» how much power can stock D3VE heads support?
» Stock D3VE heads and C6 for sale
» Torker II and cj ports???
