A460 intake gasket
+8
kjett
tconnection
12 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: A460 intake gasket
.tconnection wrote:Now that I got the intake off I see there's a liquid sitting on top of the intake valves. It don't know if its gas or oil. Im fixin to post a pic. The stuff is greenish looking.
Mine does the same thing. Its fuel as far as I can tell.
norm- Posts : 261
pic
Last edited by tconnection on September 29th 2013, 11:54 pm; edited 1 time in total
tconnection- Posts : 866
I think this stuff smokes when it burns. How does it hang around so quickly upon shutting the engine off? I notice to that I had a leak at a hose fitting and on the floor is like a greenish oil spot. Does all of this type fuel have this type stuff in it?
What kind of fuel are you using some leave a blue look behind and some leave a green look for what I have seen. The turbo blue I was running before going to alky left a blueish look on my gaskets and things.
It's most likely the Race Fuel . Mine would do that when it was on RF.
I would think the port wall gets a film of fuel that will run to the lowest point once the engine is shut off.
norm- Posts : 261
This fuel is a 114 octane vp or sunnco. I got a quick fuel 1250 on it and my plugs get black or are always black. Is to much gas feeding at idle or when the motor is reved a few times?
I had a couple of issues with the TFS intakes, one being a porosity issue. They will stand behind their product and make it right. Atleast they did for me.
soupbean- Posts : 637
I talked with tfs today and the intake did have an issue. They said that they could stop the seeping if i wanted to save my port work or they could send me a new one. I chose the new one and a set of 1/6'' gaskets. Im fixin to order an offset manual brake kit from skinny kids so i can drive this thing and see what's up with these rings seating.
I got my new intake today. Now i gotta get started porting it and gasket matching. Is there any special points that need to be focused on? Im just going in to get all the roughness out and leave a 80 grit finish.
Any info on porting this intake will be great.
Delete
I assume trickflow make nice stuff but for this a460 R intake to cost so much, it dont come out of the mold to nicely. I wouldnt run it straight out of the box. To much flashing. ''F''
» intake gasket for a460
» Best Intake Gasket A460
» A460 Intake gasket separated
» A460 ford motorsport single 4 intake brand new never bolted on port matched to felpro gasket and they come with it. $300 shipped in the 48
» felpro intake gasket # for use with vicktor or tfs intake ?
Page 3 of 3
