Eagle VS Scat rotating assemblies.....
XYPROSTREET
Tennessee Bullitt
Looking at 2 kits and I am planning to go with the Scat. Was looking for feedback with personal experence. Which is a better setup.... Scat with 9000 4.5 crank with forged I beam rods and forged pistons or the Eagle 4.5 cast crank with h beam rods and forged pistons. $1400 for scat and it comes balanced, I am looking for 600+ hp with solid cam and then add some nitrous, just a little . 6,000 to 6,500 rpm's max.
Re: Eagle VS Scat rotating assemblies.....
There has been a lot of discussion on cranks and the nod goes to the Scat for the quality of machining and product. I have a forged Scat and it is a very nice piece of equipment. Even at your lower level of hp and rpm, I'd still advise to use a forged crank, H-beams and forged pistons. It will allow you to grow in the future if you wish to up the power level down the road. The forged cranks are easier to balance and the upgrade is minimal when you add the extra expense of the Mallory metal to get the cast cranks balanced properly. Adney Brown @ Performance Crankshafts is a member here and one of the best rotating assembly guys around. There are lots of guys here that run his stuff and noone has had a complaint. Lem Evans is another dealer for these components and also a great guy to deal with and has lots of happy customers here also.
schmitty- Posts : 4538
H-beam rods...Scat or Eagle . Scat for the crank....forged would be better with the spray .
It's like I have said in my post about what I want to build, It's all about a budget I have. I know it would be easier to change the eagle crank and add a forged one later than to change rods and crank like the scat kit. If it goes where I can't add nitrous then so be it, I wanted to weigh the pros and cons of each. The nitrous is a once in a blue moon if at all being used. I want a good solid foundation to work. I want to build this and get it running in the next month or so but I don't want to cheap out and pay for it later. Yea some things are not the best of the best but I only have about 3500 now for this build with more coming later.
Which ever route you decide to go, at least use the Scat crank.
Thanks so much Lem and Schmitty.
Scat Gets My Vote
XYPROSTREET- Posts : 35
By the time you balance the cast crank you can spend a few dollars more and get the Forged crank. You need to talk to Adney or Lem to get the details.
Eagle or Scat H-Beam rods, whichever you prefer.
Forged Pistons, shop around and you may find a deal like I did on a slightly used set. I got mine for like $400 or was it $450? And it included the pens and some head gaskets.
Good luck!
Good luck!
D. Sea- Posts : 2768
Here's a rotating assembly for sale, worth a look IMO
https://www.429-460.com/stuff-for-sale-f1/rpm-rotating-assembly-for-sale-and-misc-take-a-look-t1726.htm
I have had a bad experience with a 4.5 cast eagle crank. And after backing up to regroup and deciding which direction to go, I did a good bit of research and measuring of cranks and came to the conclusion that the Scat crank is the better of the two hands down , no comparision.
I would run a cast Scat before I would a 4340 forged Eagle. This is a strong statement, but after looking closely at the two, I will stand by it.
JMHO
JMHO
IDT-572 wrote:I would run a cast Scat before I would a 4340 forged Eagle. This is a strong statement, but after looking closely at the two, I will stand by it.
JMHO
There are several other bulders and vendors here that will make that same statement also Blake.
eagle cranks
i was told that eagle cranks are made over seas by prison inmates! anybody have any input on this? Tim Mauppin of florida performance is who told me.
pat427- Posts : 33
dont think eagle is the only one.
Diggindeeper- Posts : 800
» Stroker rotating assemblies? Who has the best deals with middle of the road parts........
» Scat and Eagle
» Eagle vs Scat cranks
» 521 2bolt block
» Cheap 460 thrasher build plan for bracket tbird
» Scat and Eagle
» 521 2bolt block
