521 2bolt block
+9
tfsbbf466
LivermoreDave
kjett
kim
v-twin
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
521 2bolt block
I have a 521 with scat cast crank ,2 bolt block jon kaase heads, comp kaase 726 lift cam,diamond 36cc dish pistons .My question is how much more can it take It's in a 2000 mustang 3.73 gear 275 pros 9.90,s on motor on spray 8.93 150 1/8 is 1.29 60' 5.712 122.68 car weight is 3300# that's at bristol,tnn
v-twin- Posts : 52
Re: 521 2bolt block
The crank would be first to go.2bolt blocks are tuff as long as the tune is good.
Re: 521 2bolt block
Rods and crank are the short fuse in the combination, and I only mention rods, because OP didn't. 2 bolt blocks, pretty damn stout as long as the RPM is kept down.
kim- Posts : 700
2bolt block
well let me ask in a different way is 8.90s' safe It will go 8.60s' I don't want to hurt it before I build a good engine this winter .Right now it is smooth and runs great for what it is
v-twin- Posts : 52
Re: 521 2bolt block
if you gona build a new one this winter then thrash it! its hard to say what a cast crank can take. stay on the safe side with the tune and maybe you wont find out.
Re: 521 2bolt block
spray the rods out of it........
Re: 521 2bolt block
Amenrichter69 wrote:spray the rods out of it........
kjett- Posts : 1169
Re: 521 2bolt block
If it is a motor sport 2.5 inch crank pin cast crank made by scat, you probably wont break it.
I may be wrong on who made that crank for Ford. But it has a good bit of overlap, and the cast Scat cranks are very tuff.
Re: 521 2bolt block
cool40 wrote:if you gona build a new one this winter then thrash it! its hard to say what a cast crank can take. stay on the safe side with the tune and maybe you wont find out.
kjett wrote:Amenrichter69 wrote:spray the rods out of it........
..... or, take care of it! An engine as you describe should have value. Offer it for sale while in good condition and reinvest the funds.
Dave.
LivermoreDave- Posts : 972
Re: 521 2bolt block
It's for sale . Will trade on block and heads . Would prefer new parts . Will be at Bristol oct 5 with car. I have to run Willard kinzers black corvette. He's 85 years old but dam he's good. My only chance is he will be late or red light. It's a best of 2 out of three . We raced last night and I red lighted ,after that someone broke and oiled down his side of the track. Race was put off to oct, 5. So I may put a nx port nos on it this coming week. Because we will start where we ended . Go to racethis on face book for pictures and video
v-twin- Posts : 52
scat crank aw brown rotating kit
IDT-572 wrote:If it is a motor sport 2.5 inch crank pin cast crank made by scat, you probably wont break it.
v-twin- Posts : 52
spraying the rods
the engine braking is not the problem ,its the 150 mph with oil on the tires, yes I know the guard rail will slow it down.
v-twin- Posts : 52
Re: 521 2bolt block
That's a nice running Mustang. It WILL run probably 2 tenths faster away from Bristol.
bristol
come to Bristol oct 5 heads up racing, there's a few 760 cars. Most are mid to high 8's. You will be paired to your best time 1 tenth breakout . Last week 9.40 was cutoff out off the 16
v-twin- Posts : 52
Re: 521 2bolt block
Bristol is a beautiful facility for sure. The only thing I have against it is the air for racing. Sounds like a fun time,Good luck;)
air
yes it is bad but everyone has the same problem,so it's not just one person. My 8.93 recalculated to 8.60 with good air. IT recalculated to 3800 feet
v-twin- Posts : 52
Re: 521 2bolt block
I have a scat crank 514 that i just started spraying with a 73 jet. Plan to hit it with 93 After a tighter converter goes in. Good to know they hold up. Do the smaller stroke cranks hold up better? Mine is 4.15
Car is flying. With that big of a dish I'm assuming the compression is pump gas friendly. Do you street drive it?
tfsbbf466- Posts : 180
521
yes drive it to the track pump gas. 3.73 gear 2.75 m/t pro's 3300 lbs . 9.90 on motor at Bristol which is 2-4 tenths slower. When I first went to the track they didn't believe it was pump gas ,but one person in a Camaro saw me at the gas pumps. 8.93 150.8 with racing fuel and nitrous.
v-twin- Posts : 52
Re: 521 2bolt block
so with that being said about how fast you are running! would that be the hp limit for that crank? from all the info Iam getting from this site and other sites the scat 9000 cranks are probably good for a low 9 sec to high 8sec car which is more than most are looking for! but for anything above this you are going to need a forge crank no question asked!
nitrous.f- Posts : 294
2bolt 521
I'm pulling engine next week, engine will be for sale. Going with new short block
v-twin- Posts : 52
Re: 521 2bolt block
iam very impressed with what you have done with a #3300lb car! look at it on youtube and I like what I seen from the video! iam building one a little bigger but with the same interals! much run lighter car to 2700lbs. so I should be able to run the times iam looking for based on your car and times! thanks a million!
Re: 521 2bolt block
more info and vids on face book ,, type in racethis.
v-twin- Posts : 52
Re: 521 2bolt block
I've been tryingrichter69 wrote:spray the rods out of it........
v-twin- Posts : 52
Re: 521 2bolt block
Where will you be running?nitrous.f wrote:iam very impressed with what you have done with a #3300lb car! look at it on youtube and I like what I seen from the video! iam building one a little bigger but with the same interals! much run lighter car to 2700lbs. so I should be able to run the times iam looking for based on your car and times! thanks a million!
v-twin- Posts : 52
Re: 521 2bolt block
iam from Cleveland ohio! hey v twin iam not on facebook,so can you put some of those videos on here so I can see more! thanks!
Page 1 of 2 • 1, 2
» distributer block hole is too small on an A460 block
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» Will a manual block plate from a 77 bronco fit a 71 429 thunderjet block?
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
Page 1 of 2
