521 2bolt block
+9
tfsbbf466
LivermoreDave
kjett
kim
v-twin
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 521 2bolt block
I'm just now learning how to paste and copy youtube, type in 'racethis' all mine is for 2013 races some of the races are long. Speaking of Cleveland I sold the engine out of my superstreet car to a guy at jet express 67 or 68 mustang. It was a small block yates, ran low 8's no nitrous.nitrous.f wrote:iam from Cleveland ohio! hey v twin iam not on facebook,so can you put some of those videos on here so I can see more! thanks!
v-twin- Posts : 52
Re: 521 2bolt block
hey v-twin how long have you been running that scat crank in that motor?
nitrous.f- Posts : 294
521
engine was put together in 2007 but never driven until spring 2012 about 800 street miles. I didn't know it was 9.6 to one compression until 3 weeks ago. I got my stroker kit from AW brown, performance crankshaft in Michigan.nitrous.f wrote:hey v-twin how long have you been running that scat crank in that motor?
v-twin- Posts : 52
Re: 521 2bolt block
thanks bud for replying back so fast! like someone else has said, if you added more comp to that motor and loose some weight like 2900-3000lb it will get you the 2-4 tenths you are looking for!
Re: 521 2bolt block
hey v-twin hows it going? are you still running that same motor with the scat cast crank in there! about to take my 4.500 scat cast steel crank and eagle 6.7 rods je pistons to get balanced. how many slugs did it take to get balanced? going to run it the way it is. blocks good to about 800-1000hp crank 850-900hp so what the hell!
521
rebuilt the engine this past winter , bumped the compression up to 13.6 . used one of Lem Evens cams and a Steve Johnson port kits .. Was trying to break in the engine without nos ,spinning real bad , So the next week was power hour but I won that race, only used the plate on last pass because the guy I was running broke last round .300 on plate 138 in 1/8 153 1/4 The next week tried the port as a second stage 300 at about 100 mph it came in and lifted the front . But that was short lived, burnt seven plugs and didn't know about the seven melted pistons till the next pass I switched back to the plate and went 8.93 156 blew the oil ring off one piston blew the top off three . The second stage had no fuel. But all is good now bored to 4.440 diamond nos pistons ,reline bored the block 8 exhaust valves, one intake. I just got the short block together tonight. finish it up tomorrow. I hope to be burning rubber Monday and racing Thursday good luck with yours
v-twin- Posts : 52
Re: 521 2bolt block
When you say the second stage had no fuel... Do you mean NO fuel, or just not enough fuel jet in the tune?
460bronco- Posts : 364
521
yes "o" no fuel going to hook everything up Monday and test the intake in a big pan and see if I can trace the problem. I flowed the nx plate through the solenoids no problem there. will see Monday
v-twin- Posts : 52
Re: 521 2bolt block
hey v-twin do you still have the cast steel crank in there? I love your build! that thing is flying! got the 4.500 scat 9000 balanced with the 6.700 rods and je pistons ready to put together! give me a call will love to talk to you about your combo! ask for tim (216) 754-0938
Re: 521 2bolt block
kim wrote:Rods and crank are the short fuse in the combination, and I only mention rods, because OP didn't. 2 bolt blocks, pretty damn stout as long as the RPM is kept down.
Yea, I never ran mine above 8800...
Re: 521 2bolt block
Yep, a man's got to know his limits. I kept the 552 below 7200.HorsinAround wrote:kim wrote:Rods and crank are the short fuse in the combination, and I only mention rods, because OP didn't. 2 bolt blocks, pretty damn stout as long as the RPM is kept down.
schmitty- Posts : 4538
Page 2 of 2 • 1, 2
» distributer block hole is too small on an A460 block
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» Will a manual block plate from a 77 bronco fit a 71 429 thunderjet block?
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
Page 2 of 2
