IDT vs. A460 Blocks
IDT vs. A460 Blocks Empty IDT vs. A460 Blocks
Post  Stangman98 October 20th 2009, 11:43 pm
I apologize in advance if this has been covered. Which one would be better for a 604CID build? The IDT look like damn nice blocks. Is there an advantage in running those over the A460?
Stangman98
Stangman98
http://www.racestangs.org
IDT vs. A460 Blocks Empty Re: IDT vs. A460 Blocks
Post  schmitty October 21st 2009, 12:56 am
IDT Premier blocks will handle a 4.700 bore other than that both good blocks. Cool
Post  rmcomprandy October 21st 2009, 10:16 am
In my opinion the IDT is a better block however, it requires quite a bit more prep work.
How good is good enough - is totally up to you.
Post  chuck stevens October 21st 2009, 11:47 am
Randy, could/would you expand a bit on any additional work required on the ELIMINATOR blocks, as opposed to the A-460?
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  rmcomprandy October 21st 2009, 4:55 pm
Let's start with ANY machined surface on an IDT block where you won't cut your hand on the edges to clearancing the bottom of the bores and the distributor area to the necessary attention to the oiling system.
Just the de-burring takes one helluva lot more time than with an A460 if you do it all.
Of course, if your time is worth almost nothing then it is almost nothing to do it.
