Quick Fuel Float Question
I have a 1250 Dommy Quick Fuel . When I am looking at the site glass to set the fuel level one side is lower than the other. On the Pass side of the car the fuel comes in and I set the floats on that side. Well when you walk around to the Driver side the float level is down almost to the bottom of the glass. Its like that on the primary and secondary. Is this supposed to be this way.
I have had some issues with the carb idling and I notice adjusting the fuel level is kind of touchy with idling problems.
Yes the car is sitting level . I have had this carb apart 2 times and can't see anything wrong.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: Quick Fuel Float Question
Tore, you been drinkin again? your car is sitting on a hill........... Just kidding, it shouldn't bee that way.
Park it on a hill and see if it helps
so on one side the glass is half empty and the other side its half full.............
IDT-572 wrote:Tore, you been drinkin again? your car is sitting on a hill........... Just kidding, it shouldn't bee that way.
Thanks guys!!!
Tore- Posts : 865
Tore wrote:IDT-572 wrote:Tore, you been drinkin again? your car is sitting on a hill........... Just kidding, it shouldn't bee that way.
Thanks guys!!!
Have you set it on a level work bench and filled the bowls through the vents and see what that does?
Sorry about the jokes............
No I haven't done that but thought about it after I bolted it all back together.
The jokes are ok with me.
Thanks for the help.
Tore
Tore
Tore- Posts : 865
Tore wrote:No I haven't done that but thought about it after I bolted it all back together.
Tore
Who's joking?
Don't feel to bad Tore, I've had a trying day also.
» Quick Fuel Carb QUestion
» 60' time - how quick is too quick for mech. fuel pump?
» 4500 vs 4150
» Quick fuel
» 1250 Quick fuel
» 4500 vs 4150
» Quick fuel
» 1250 Quick fuel
