60' time - how quick is too quick for mech. fuel pump?
I've read on the other site in the past that the main reason to go to an electric fuel pump isn't so much actual hp, but the G-forces of the launch can actually overcome the negative pressure (sucking) of a mech pump.
Is everyone in agreement with this or a bunch of bull?
I'm debating on whether or not it's worth the hassle and expense of upgrading to an electric fuel pump for my street/strip car.
With my new combo I would expect 60' times in the low-mid 1.5's.
Hp in the 525 range.
somethingclever- Posts : 107
Re: 60' time - how quick is too quick for mech. fuel pump?
Don't now agout the g-force deal on it but I like the elec. pumps for alittle HP gains and takes alittle stress off the cam and timing chain less drag inside the engine = more hp Just my thought on it,If that helps you any.
Jim
Jim
If your talking about the diaphragm type mechanical pumps, yes G forces can affect its pumping ability. They are trying to pull the fuel from the tank in the rear, whereas if you have an electric pump mounted back at the tank, it will be pushing the fuel forward. More efficient IMO.
Yes I realize the hp benefits (although probably pretty small) with the electric fuel pump....however it's quite an expensive upgrade for what I would assume, a 5hp increase.
That's why I'm curious if the G-force statement is true, and if anyone here has experienced it first hand, and what their 60' times where.
Right now I have a 110GPH holley conventional style diaghram pump and I'm expecting around 525hp.
» Power loss of mech fuel pump?
» Relation of mech. water pump to Meziere
» Bracket/s to mount a mech. fuel pump and an alternator
» Quick Time bellhousing
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
