Opinions on what intake would suit best?
500-528 inch engine out of the box TFS Streets or Super Cobra jets, 230-240 hyd solid flat tappet 108-109 sep .550 lift 3500 lb street vehicle 2000-2500 stall.
Ported Edelbrock Torquer two or Performer RPM?
I'm looking hard at the Torquer two.
Re: Opinions on what intake would suit best?
IDT-572 wrote:500-528 inch engine out of the box TFS Streets or Super Cobra jets, 230-240 hyd solid flat tappet 108-109 sep .550 lift 3500 lb street vehicle 2000-2500 stall.
With that vehicle;
If direct "off idle" part throttle response is not a major priority then the Torquer II would be my choice.
rmcomprandy wrote:IDT-572 wrote:500-528 inch engine out of the box TFS Streets or Super Cobra jets, 230-240 hyd solid flat tappet 108-109 sep .550 lift 3500 lb street vehicle 2000-2500 stall.
With that vehicle;
Thats were I'm at in my thinking, with the bigger inch engine and smaller cross section of the runners air speed should be good a little of idle and with a straight shot to the valve maybe flow will be better to take advantage of the better heads.
Direct off idle will be hard to get with the cam chosen anyway. I want to test this someday.
That cam doesn't sound to far off of an old Crower cam that I ran in a 472 with a DOOE intake. It was a little slow off idle with a stock converter, but came on real strong and pulled hard to about 6k. I should have had a 2500 or so stall converter in it. Add 15% or so cubes to that engine, and better heads(I was using almost bone stock C9's) and it should be quite a runner. This engine was in a 79 F250 Extended cab 4X4 that weighed about 8k.
schmitty- Posts : 4538
What's a hyd solid flat tappet?
dfree383 wrote:What's a hyd solid flat tappet?
It's midnight at the oasis, put your camel to bed................. Now put music to it
IDT-572 wrote:dfree383 wrote:What's a hyd solid flat tappet?
» Opinions wanted on intake and heads for my 466!
» col suit ????
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» Advice re inlet manifold to suit 521
» Intake manifold design ~vs~ Intake air temp.
» col suit ????
