OLIVER RODS QUESTIONS
GUY'S I'M THINKING HERE (BAD THING). I'M CONFUSED. I have a set of new oliver rods and i think they require to torque there bolts to a certain angle or stretch? why if the bolts are ARP and they recommend a specific torque. i lost the paper work at this time so i'm just pondering here
Ace
Ace
powerstrokeace- Posts : 1496
Re: OLIVER RODS QUESTIONS
If you talk to any fastener design guru they will tell you that the best way to measure the clamping tension is by the stretch of the fastener. Using torque only is a simple quick method that generally gets you in the ballpark. If you want to be certain stretch is the preferred.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Here is a link to Oliver's web site...The bolt stretch specs are in the catalog section. http://www.oliverracingparts.com/downloads/ORP_Catalog_2013.pdf
It depends on the bolt you have. The BBF applications that I commonly see use the Oliver/ARP WSB bolt that stretches to .0053" to .0057" using the supplied ARP or Oliver moly type lube. I just always remember .0055" for those.
Keith
Keith
These rod have been on my shelf for 13 years so I guess they are the 6.800 Chevy rod.
Ace
Ace
Call Oliver up, they seem to change the specs from time to time.
» Oliver rods
» Rod Lenght Question on Oliver rods
» BILLET OLIVER RODS 6.800
» Oliver Rods for sale
» sold Oliver Rods
» sold Oliver Rods
