Oliver rods
Oliver rods
I have a question about a set of Oliver rods that I purchased used here a while back. How do you tell what rods you have, there are no numbers or any designation of any kind that I can find.
AZFairlane- BBF CONTRIBUTOR
Re: Oliver rods
Yup. And then you can date them by the type of bolt used. Oliver changes the bolts every other year or so. So look at the ARP fastner used and you have your manufacture time frame.
kim- Posts : 700
Re: Oliver rods
There was a period of time when the standard bolt was made by A1....they are not all ARP bolts.
Re: Oliver rods
I'm sure these are 6.8, but isn't there a difference between Ford and chebby rods, something about an offset in the big end.
Re: Oliver rods
Yes. The chevy ends have a wider main journal. Because my rods were orderd 2.100 journal end they came chevy width. After talking with oliver.. they said just mill em down to ford width. The offset is on the non chamfer side. Didnt take anything to knock em down to ford width.
kim- Posts : 700
Re: Oliver rods
About how much material did you have to take off?
Re: Oliver rods
One of the numbers I dont remember. Sorry...
kim- Posts : 700
Re: Oliver rods
No problem, thanks Kim
Re: Oliver rods
All of the aftermarket crankshafts I've used were set up for the ~ .990" bbc big end width.
How wide are the rod journals on your crankshaft?
Re: Oliver rods
Customn billet from scat. 2.100 journal, ford width.
kim- Posts : 700
Re: Oliver rods
http://oliverracingparts.com/downloads/ORP_Catalog_2013.pdf Page 11 has some info.
supervel45- Posts : 4499
» Oliver or Callies Ultra rods
» Rod Lenght Question on Oliver rods
» BILLET OLIVER RODS 6.800
» Oliver Rods for sale
» OLIVER RODS QUESTIONS
