which tranes
+13
2fox
STHAZLET
61coon
bigjohn2007
whitefield
sskwb
17 posters
which tranes Empty which tranes
Post  sskwb June 9th 2013, 9:52 am
running a 700 hp bbf, 10.5 slick or 315 drag radial, ladder bar, 4.10 9" gear.3100lbs, 95 mustang in no box foot brake racing or street class, 1/4 mile racing
what trans? power glide, c-4,c-6 ?
1) will the tire handle the tall first gear of the c-4 or c-6
2) will a well built C-4 handle the bbf long term
3) WILL THE CAR BE A DOG ON THE STARTING LINE WITH THE POWER GLIDE?
4) reliability and consistency being most important
thanks in advance
sskwb
which tranes Empty Re: which tranes
Post  dfree383 June 9th 2013, 10:41 am
PG for the win on small tires. I went 10.1's with a glide, Iron heads, 3.89 gears and 28x10.5's for years..... It wasn't a dog.
Post  whitefield June 9th 2013, 10:57 am
sskwb wrote: running a 700 hp bbf, 10.5 slick or 315 drag radial, ladder bar, 4.10 9" gear.3100lbs, 95 mustang in no box foot brake racing or street class, 1/4 mile racing
thanks in advance
What is the engine build head compression ect.?
In my opinion at 700 hp bbf with the weight of the car it wouldn't last long . Freshen ups or rebuilds would be a constant thing with the c4.
C6 would work and be consistent if the trans is built right and has the right Valve body. Suspension tune from my experience is a little harder to get right with a c-4 or c6 over a glide! I think The C6 would be a good choice and that is what I would run!
For most the glide will be more cost effective for future higher hp build and consistency . You may have to change the gear ratio to like a 4:30 with the PG to make it launch the way you want . I hate to say it but, a PG is a good choice and has a lot of aftermarket support.
On any of the transmissions that you choose a good converter and Valve body are going to be a must ! good luck! Smile
whitefield
whitefield
Post  bigjohn2007 June 18th 2013, 10:28 am
Glide will make u happy..
bigjohn2007
bigjohn2007
Post  richter69 June 18th 2013, 4:37 pm
PG.......
Post  whatbumper June 18th 2013, 9:30 pm
Glide
Post  IDT-572 June 18th 2013, 11:25 pm
You will be more consistent with a glide on the 10 inch tire.............
Glide for the win:cheers:cheers
Post  61coon June 18th 2013, 11:31 pm
Glide bounce
61coon
61coon
Post  69F100 June 19th 2013, 12:28 am
the c6 worked great for my 460 making 575hp it is stock with a B&M shift kit with TCI 4500 stall but it didn't hold up to my 552 went to slipping bad and heated up last Saturday on the 1st pass with the new 552 an it should be making 700 to 750hp.I am going to a pg now but what ever trans you decide on go head and get it built for more hp than you are running.
which tranes Empty TRANS
Post  STHAZLET June 20th 2013, 11:20 pm
A lenco drive is the toughest and the best,but is expensive.A glide would be my second choice. Best bang for your buck pg.
STHAZLET
STHAZLET
http://WWW.WEBERHAZLET.COM
Post  2fox August 11th 2013, 10:16 pm
PG are GM.transmissions ..why would u do that to a Ford?
C4 can be built to handle.1000 hp.
2fox
Post  STHAZLET August 11th 2013, 10:23 pm
Bring me your c4 bet it won't last the day behind my motor.
STHAZLET
STHAZLET
Post  the Coug August 11th 2013, 10:47 pm
Glide c-4 will not last
Post  richter69 August 11th 2013, 10:55 pm
2fox wrote:PG are GM.transmissions ..why would u do that to a Ford?
moron
Post  the Coug August 11th 2013, 11:00 pm
Ouch
Post  whatbumper August 11th 2013, 11:03 pm
Powerglides are gm. We run glides. Lol
Post  cool40 August 12th 2013, 1:35 pm
Reid racing 2spd for me... alien
Post  dfree383 August 12th 2013, 2:06 pm
Ain't no GM parts in my 2 front line units either.....What a Face
Post  whatbumper August 12th 2013, 3:25 pm
cool40 wrote:Reid racing 2spd for me... alien
okay, that's better.
Post  2fox August 12th 2013, 3:52 pm
Am going to put a 632BBC. In my stang with my C4 with 600 shot..
2fox
Post  whatbumper August 12th 2013, 4:34 pm
Boom
Post  2fox August 12th 2013, 6:33 pm
So you telling me the best PA C4 transmission rated for 1000 hp. Is junk? For a drag car that only gets appx. 12 passes in 8years?
Am not meaning to piss anyone off just sayn may be okay for me. I only have a 408W with a bigshot. Its got be be faster with the C4 then with TKO trans am running now.
Sorry to upset everyone. But everyone says c4are junk . I would say yes for a drag car that gets run every weekend with a BBF like a 514 or bigger.
2fox
Post  richter69 August 12th 2013, 6:55 pm
your stuff will never hurt one.
fwiw i run a c4 in my sb car which is honestly faster than you'll ever go.............and im not trying to piss u off.
Post  the Coug August 12th 2013, 8:39 pm
2fox wrote:Am going to put a 632BBC. In my stang with my C4 with 600 shot..
If you are going to screw up a mustang by putting a BBC in it, Then why are you worried about putting a glide in it? beside you will find some way to make it really slow any how.... Like I said before get your 408 fixed and then worry about going faster
Post  QtrWarrior August 12th 2013, 9:22 pm
Well...look who's back...
QtrWarrior
QtrWarrior
