which tranes
+13
2fox
STHAZLET
61coon
bigjohn2007
whitefield
sskwb
17 posters
Page 2 of 2 Previous  1, 2
which tranes - Page 2 Empty Re: which tranes
Post  QtrWarrior August 12th 2013, 9:25 pm
Gentlemen,
Shall we get back on topic for the OP ??pig
If 2 fox wants to continue...We'll start another thread...affraid
QtrWarrior
QtrWarrior
Post  cool40 August 12th 2013, 9:34 pm
sskwb wrote: running a 700 hp bbf, 10.5 slick or 315 drag radial, ladder bar, 4.10 9" gear.3100lbs, 95 mustang in no box foot brake racing or street class, 1/4 mile racing
what trans? power glide, c-4,c-6 ?
1)   will the tire handle the tall first gear of the c-4 or c-6
2) will  a well built C-4 handle the bbf long term
3) WILL THE CAR BE A DOG ON THE STARTING LINE WITH THE POWER GLIDE?
 4) reliability and consistency  being most important
thanks in advance
IMO,with 700hp a good c4 would live a while. i had good luck with mine but the car was 2600#.in a 3100#foot brake car the c4 may be faster than a glide.if you have any plan to go faster just skip the c4 and get a glide. Very Happy
Post  windsor August 12th 2013, 9:47 pm
thanks in advance
You said it.... That would be a pg.
Post  dfree383 August 12th 2013, 10:56 pm
2fox wrote:Am going to put a 632BBC. In my stang with my C4 with 600 shot..
Your gonna put your eye out.......... You can't get a 408 with a big shot,of NO2 to run 10's and now your going to put a 632 bbc in..... Who you bull sheetin sunshine.
Post  richter69 August 12th 2013, 11:18 pm
I see he is in my neck of the woods, maybe Ill run into him I get out and a bout........
Post  cool40 August 12th 2013, 11:55 pm
richter69 wrote:I see he is in my neck of the woods, maybe Ill run into him I get out and a bout........
maybe you guys could start a new kind of list! Razz Razz
Post  IDT-572 August 13th 2013, 5:53 pm
You put a c4 any c4 behind a good race 632 @ 3000 lb and hook it on a 600 shot........................
And you can go to your trailer and get a corn scoop and scoop up all the parts from the starting line out to the 60 ft line where it spit that c4 out...................Razz Razz Razz
You will put a BBC in the car and not put a glide.............. I'm confused:scratch:
Post  2fox August 14th 2013, 11:56 am
So a PA SC C4 wont last behind a 557 with alum SCJ heads for summitt. with pump gas comp. I don't run a lot just for time. Not for money.
With a litttle nitrous later.
The BBC is just a joke..I know people.with chevys that don't like to run.9 inch rear ends lol. But I have on. Am tryingng to be serous now.
2fox
Post  IDT-572 August 14th 2013, 12:08 pm
2fox wrote:So a PA SC C4 wont last behind a 557 with alum SCJ heads for summitt. with pump gas comp. I don't run a lot just for time. Not for money.
It will last on a pump gas 557. How long is just a guess. What happens is , if you gear it to turn the shift light on at the end of the eight mile with a short 28x10.5 tire it is going to have a very low final drive ratio in first gear and be hard to hook, violent leave and inconsistent.
A 557 10.5 comp may have up to 650 maybe 700 ft lb of tq. 700 x 2.46 fist gear x 4.30 ring gear=7404 lb of torque to the tires. And then your converter can multiply torque up to 1.5 to 2 times, now you could be as high as 14,809 lb of tq to the tire.
1/4 mile track will work with a 3 speed with your combo as far as gearing , but the chance of breakage is still there.
A glide is cheaper and just a better deal for a BBF 1/8th mile bracket or weekend warrior.
Now for the street and street tires put the c/4 in it and a 3:00 gear and have the best of both worlds.
Post  2fox August 14th 2013, 9:45 pm
I have a 86 LX notch tubbed witb 14x32's ,ladder bars 4,30gear spool.33 splines. Has dash still but completely gutted no bumper bracket. Mar just forget about th nitrous. ? 8 pt.cage but have a 10 pt converson kit. Or could just stick with a 351W based mtr. I akways buy something then plans change, has that happenes to anyone else? I love tq.
2fox
Post  IDT-572 August 14th 2013, 10:28 pm
Dude take a breath calm down step back get a simple plan together and follow it through till it 's finished. Then if it gets boring to you after a spell then up grade.
Post  bbf-falcon August 16th 2013, 8:22 am
I have a really good friend that is as die hard ford as they come. He has a 830hp FE in a 58 Ford w/PA C4. After the 4th rebuild PA told him they were denying his Lifetime warranty. So he made a few changes to it and actually accomplished a few extra runs from it. Well,it went south again last month at Norwalk. The case was busted along w/other inside parts. He called PA again and talked to the owner about it. So.they agreed to replace the case and rebuild again.Its back in the car again heading to the Geezers race at Kilkare. Keeping our fingers crossed.
I agree w/you guys,a racing 2 speed is the way to go w/big hp.and consistency.
Post  maverick August 18th 2013, 10:49 am
2fox wrote:So you telling me the best PA C4 transmission rated for 1000 hp. Is junk?  For a drag car that only gets appx. 12 passes in 8years?
I don't know that I'd put myself through all the hassle to make a pass and a half each year.Wink  Flog your pickup truck.Smile
BTW, the 'glide is the way.
Post  IDT-572 August 19th 2013, 8:44 am
[quote="2fox"]So you telling me the best PA C4 transmission rated for 1000 hp. Is junk?
No it is not junk, but there is another part of the equation you are not looking at or giving thought to, T.Q. and R.P.M.
Low RPM and high Tq Kills C/4's. Big block Fords have this even the smaller cubic inch ones are above the majority of small blocks in this area.
I just had a 472 on the dyno that made over 650 ft lb of Tq. @ 4800 rpm cam was short and on a narrow separation. That was on gas, it made almost 700 on alky.
A 1000 hp small block will be short on tq and high on rpm, C/4 may last behind that combo. But I doubt it.......... for long:roll:
Post  richter69 August 19th 2013, 9:42 am
This C4 in my sb car hated life when it was in my BB car, Im at about the same power level now and its real happy. Car is 200 pds lighter, way less TQ.
Its all about application.
