c6 with transgo shift kit .. problem
bb429power
Captainp4
Hi, I'm posting here from recommendation of a friend. I just finished installing the transgo shift kit and a new trans pan on my c6 in 78 460 Bronco and I'm having a problem. In reverse it doesn't seem to want to move unless you rev the crap out of it and even then not very much. In drive/1st it engages and pulls as soon as shifted. I did not have the space to try leaving in drive and letting it shift to second, so unsure if that works correctly at the moment.
I used a PML pan, new filter, and dexIII/m fluid if any of that is important. And just because I think it looks so good, PML makes a real quality piece even if it is a bit pricey:
Edit: It feels like when the fluid is low and it sort of grabs but still slips... In fact I over filled it because being a dumbass I wasn't checking the fluid level as I filled, just going by how it felt when shifted into gear. Not sure if being over filled would cause this problem.
Captainp4- Posts : 17
Re: c6 with transgo shift kit .. problem
I am not very knowledgeable on transmissions but that looks like a deep sump pan, do you have the filter spaced down or sitting lower like the pan is or the stock filter? I ran into that issue with a c4 but it didn't act up like yours is doing.
An expert will be here shortly with an idea or answer
bb429power- Posts : 3129
I used a stock style filter/pickup. Seems like it would have problems both directions if it was a pickup problem, but I'm no expert either.
I just did a transgo kit in mine maybe a month ago, it was the 1 2 "reprogrammer" which is what they told me to go with. Which kit did you install? Did the problems start after the kit or were there any pre existing problems? Maybe a check ball or spring is amiss in some way. And you're probably right about the pan depth causing an issue forward and back.
Also, did you install the valve body gasket? Sounds dumb but I've seen many people say not to use it because it "could cause issues if it breaks down the road"...I used it
Same kit, 1-2 reprogrammer. No problems before hand.
Installed the gasket between the two halves of the valve body if that's what you're asking.
I'm thinking something is just slightly off or misaligned, but came here to make sure I wasn't missing something obvious before I tore it all apart again.
I'd be rechecking the kit is installed right . Something amiss there .
All the end covers tightened last? The reverse clutch is also used in 3rd gear so need to see if 3rd has an issue as well. You have the modulator out? Valve refitted in correct way?
Really do need a deep filter for that pan to work correctly but as long as the oil level is up now enough for the filter that wont be the issue
Gregaust- Posts : 625
I did tighten the end covers before putting the halves back together, didn't read that part til after I had them tightened down, guess that might be more important than I thought.. lol
especially if there sitting proud to the mating surface
Frank Merkl- Posts : 1524
Frank Merkl wrote:especially if there sitting proud to the mating surface
Sounds likely..
On a similar note.. I managed to forget to torque down the VB bolts the first time I set up a C6.. it "shifted" all sorts of goofy, if at all..
Well started it up earlier, reverse worked fine.. but felt like it was slipping in the upper end of 1st and didn't really want to shift to 2nd without slippage. Not enough room in driveway to make it to 3rd.
So I tore it all apart again and checked spring placement and all looked good. Followed the directions this time for reassembly. Did find some junk in one of the channels in the VB so cleaned all that up. Just came in from putting it all back together and dumping some fluid in. Too later here to start it up right now and check, so will have to wait 'til tomorrow for the verdict.
I also accidentally pushed the large springy clip piece in too far and it got turned around so I couldn't get it back out. Not sure if this will affect anything, but I couldn't get that thing out.
Paul, if that don't work, come grab my spare valvebody and run it!
kjett- Posts : 1169
» FORD / MERCURY C-6 Floor shift axle / shift lever
» c4 shift issues
» shift
» SBF C-6 will shift into 3rd gear at WOT
» C6 doesn't want to shift into 3rd
» c4 shift issues
» shift
