Carb Spacers
geno
Carb Spacers
Could someone please explain in layman terms the ins and outs of carburator spacers. How do you determine if one is needed and if so, what size. Thanks in advance.
Geno
Geno
geno- Posts : 103
Re: Carb Spacers
whats your application?
Re: Carb Spacers
They have tendencies however, the results are NOT carved in stone.
The only way to really know is to try several with your combination to find which one works the best for you ... otherwise it is simply an educated guess.
Re: Carb Spacers
anytime we dyno an engine we try various spacers, also apply this to on track testing.
I have a shelf full of all types of spacers as a result lol
Spacers
I have a 532 in a '71 Pinto with a 456 chunk and a C4. I have a glide now but wanted to add a spacer to help the top end out with the trans change. I have a 2" and a 1" so to the track for some testing. I have also thought about adding nitrous. Does that work with a spacer or would the plate act as a spacer.
THANKS,
Geno
THANKS,
Geno
geno- Posts : 103
Re: Carb Spacers
the 1" supersucker or powercone spacers seem to work good most of the time. Again your just gonna have to do some testing. most nos plates are 1/2" thick but some are 1"....... again testing will tell the tale.
Spacers
Thanks to all. I will start my testing with the NX plate (twin 6) and the smallest spacer and work up from there.. Thanks all. Geno
geno- Posts : 103
Re: Carb Spacers
;)The heat isolation is worth having one regardless of h.p. gains.
J
J
Dave C.- Posts : 1268
Re: Carb Spacers
Have you read this, might help.
https://www.429-460.com/t11379-carb-spacer-airflow-test
I realise it will be different on different applications but should give you a ball park.
austin460- Posts : 79
Re: Carb Spacers
There is a sticky somewhere for spacers.
342g- BBF CONTRIBUTOR
Spacers
I will try both the Wilson and the Jomar both with and without a nitrous plate.
geno- Posts : 103
Re: Carb Spacers
turn that NX plate on and you'll forget about a spacer!
» Carb spacers??
» 4500 Carb Spacer's
» 4500 carb spacers 2
» Oil pan, cams, carb spacers, crank adapter
» weiand carb adapter 4500 carb flange to 4150 intake
