kaase oil pump
kaase oil pump Empty kaase oil pump
Post  Larry Williams June 15th 2013, 4:10 pm
is it acceptable to reduce the size of the outer side of the oil pump for pan clearance?
Larry Williams
Larry Williams
kaase oil pump Empty Re: kaase oil pump
Post  Lem Evans June 15th 2013, 7:58 pm
Larry Williams wrote:is it acceptable to reduce the size of the outer side of the oil pump for pan clearance?
Are you speaking of the end cap?
Post  rmcomprandy June 15th 2013, 8:33 pm
I think he is referring to the outside of the 2" thick mounting area.
I have trimmed a little off it in the past so the pan side will clear it.
Post  Lem Evans June 15th 2013, 8:40 pm
I haven't seen that issue........thanks for the input.
Post  Larry Williams June 15th 2013, 9:48 pm
i do mean the outside edge of the 2" part.   pan fit is close but it needs an adjustment
this is on my 545 stock block motor
I was thinking of massaging both the pan and pump for clearance.
Larry Williams
Larry Williams
Post  dfree383 June 15th 2013, 10:43 pm
I've had to clearance the inside of the mount to clear cranks before. Never had to clearance for a pan. What pan are you running?
Post  Larry Williams June 15th 2013, 11:25 pm
its a moroso   I got from lem
Larry Williams
Larry Williams
Post  dfree383 June 16th 2013, 12:30 am
can you post some pics and point out where the issues are?
Post  Larry Williams June 16th 2013, 12:04 pm
dfree383 wrote:can you post some pics and point out where the issues are?
will try later
Larry Williams
Larry Williams
