Kaase Oil Pump ?
ebustin
RGL
Kaase Oil Pump ? Empty Kaase Oil Pump ?
Post  RGL May 23rd 2010, 9:01 pm
anybody offhand know the size of the gear used in the pump ? just trying to make a comparison.
thanks for any help
RGL
RGL
Kaase Oil Pump ? Empty Re: Kaase Oil Pump ?
Post  the Coug May 23rd 2010, 9:05 pm
Let me ask you a question...... Why does it make any difference what the gear size is the pumps are the best out there bar none they hold consistant oil PSI and do not Break like the mellings do sometime.... They cost a little more than a regular Melling but What is your Engine worth? would it not be wise to have a great pump instead of wondering when it will break?
Post  Lem Evans May 23rd 2010, 9:26 pm
1.1" rotor.
Post  richter69 May 23rd 2010, 9:27 pm
Its not the gear size that makes the pump better than the others.
Post  RGL May 23rd 2010, 9:49 pm
thank you Mr Evans .
I'm aware of the qualities of the pump, i just wanted to make comparison on the pressure section on my external pump
RGL
RGL
Post  ebustin May 28th 2010, 12:06 am
Are Kaase's oil pumps taller then Speed-pro HD pumps. I want to get the pump, need to find out about the pick up for a 10 " sump I hope mine will fit.
ebustin
Post  dfree383 May 28th 2010, 9:00 am
The pick up point is in the same location as the s
compairable melling pump.
Post  rmcomprandy May 28th 2010, 9:23 am
ebustin wrote:Are Kaase's oil pumps taller then Speed-pro HD pumps. I want to get the pump, need to find out about the pick up for a 10 " sump I hope mine will fit.
The cover height/depth is taller because of the "dual-fill" capabilities of the pump.
The physical thickness of the pumping unit is of little consequence when you don't fill that cavity in the pump "all the way". Filling it from both sides completely fills the Kaase pump, (and original CJ pumps), to make a smaller pumping unit pump like a larger unit with less aeration.
Post  ebustin May 29th 2010, 2:04 am
This is all good info, but I still need to know if I need a new pick up if so which one when using Kaase oil pump.
ebustin
Post  bbf-falcon May 29th 2010, 6:50 am
Ya should be able to use the same pickup tube.My Kaase pump was originally bought/ purchassed for my Front sump Maverick engine. When I tried to use it w/my Moroso Fox body pan it would'nt let the pan bolt up and was hitting the bottom of the pan in the front. I had to make a little drop down in the front for ir to clear.
Post  ebustin May 29th 2010, 10:59 am
I miss spoke. I have a 8.5 front sump Moroso Road Race pan
ebustin
Post  Lem Evans May 29th 2010, 11:01 am
Then you'll need the ft sump pump........there is a ft and a rear model.
Post  Daytonatunnel May 29th 2010, 11:25 am
ebustin wrote:This is all good info, but I still need to know if I need a new pick up if so which one when using Kaase oil pump.
Same p/u tube as stock. I had a Melling unit, purchased the Kaase pump and it bolted right in place, no changes required.
P.S. I have a rear sump application w/an Armondo's 10qt. pan.
Daytonatunnel
Daytonatunnel
Post  Lem Evans May 29th 2010, 11:35 am
The rear sump mounting is the same ht. as the melling......i'm not sure that's the case on the ft. model.
Post  rmcomprandy May 29th 2010, 11:59 am
CANTON makes a pick-up which uses a rear sump, ("D" type pump), oil pump with a 8 1/2" deep, front sump pan.
The front sump pump uses a CJ pick-up.
Post  bbf-falcon May 29th 2010, 12:02 pm
The front sump # will also work on the rear by switching the blockoff and the pu tube around. Modifications may be required Smile
