429 CJ cam advice
429 CJ cam advice
I have a stock 70 Torino, 429 CJ, 4spd with 3:50 gears. I would like a solid flat tappet cam reccomendation please. I am adding a torker II intake, 850 DP and headers. Car will not see a lot of use but I want it to scream when I do use it. Rough idle is not a concern. I did send Scott a pm to get his advice. Thanks
Super CJ- Posts : 30
Re: 429 CJ cam advice
Get a CUSTOM ground camshaft for exactly what you want the car to do. In most instances, from vendors on here, the cost isn't much, if any, more.
There is a whole lot more information needed for you to get your engine/vehicle a cam with exactly the right temperment and manners the way YOU want it to act.
Do you want to keep the 3:50 gear?
zrob90sc- Posts : 43
zrob90sc wrote:Do you want to keep the 3:50 gear?
Yes
» ok truck guys i need advice come on in heros need motor advice also
» Need some advice
» Any one ever see hundreds like tiny holes mving down across vison all together in a cloud, not like floaters?
» I need advice on my ignition
» Need advice
» Need some advice
» Need advice
