605 ci ALL ALUMINUM MOTOR NEW PRICE
774 Super Street
STHAZLET
605 ci all aluminum motor.A96 block,4.5 steel,forged crankshaft,lightened and knife cut.
Carillo steel h beam 6.750 rods.With lsm7 bolt up grade.J&e forged,gas ported pistons.
Roller cam bearings.Comp cams roller cam and roller lifters.Double roller steel billit,
timing chain and gears.Double pinned.Motorsports heads with new Victory titanium valves
2.40 intake and 1.95 exhaust.Sheetmetal intake .Plummed for
NOS fogger.MSD crank trigger and crank trigger distributor.Has head stud kit and rocker
stud girdles .Nice aluminum
dry sump pan. JW flywheel and Fluiddampner.Balancer.Sheetmetal valve covers.
Motor was just redone And test fired never run.Finished just before I got sick.
$19500.00plus shipping. Thanks for looking steve
Re: 605 ci ALL ALUMINUM MOTOR NEW PRICE
I assume those are C460 heads? Also, do you know what kind of power it makes or what did it run in your car?
774 Super Street- Posts : 26
774 Super Street wrote:I assume those are C460 heads? Also, do you know what kind of power it makes or what did it run in your car?
not positive but i think c heads have to run shaft rockers? look like motorsport a heads to me?
dino- Posts : 46
605 ci
The heads are first edition Motorsports a heads.They work better than my TFS a heads so they were the ones I kept.I never got the chance to run this combo in my car.When I used these heads last time I had them on a 600 ci motor with less cam and not as good a piston combo.The car weighed 2550 with driver Went 8.05 on motor no nos first pass. Now motor has .050 shorter rod,better pistons and pins and set up for nos.Has wider lobe center for nos. 6 more cubes and gas ported pistons.Also went to carrillo rods and lsm7 rod bolts.If it worked like I believe it would I was goint to turn it 8500 rpm and shoot it with 200 nos. I figured it should run 7.50 shooting for 5 seconds.I ran another car with similar set up shot it and got scolded because chassis was not cert to go that fast.These heads were also used on a midwest prostock Probe that ran 6.96 best no juice.
question
what kind of spring pressures do you run with stainless rockers and girdles with success?
Mike
Mike
seefour- Posts : 3
Will ya seperate the block ?
KY JELLY- Posts : 1530
Ward
There is a fellow on this forum with a 66 Red Fairlane gta.I want his car and he needs this motor.Lets do some trading.You know where to find me.Will run 7.50 quarter in your car.I know for a fact.
Steve that is a killer motor. I'm thinking, but I just don't see how I can afford it. Even with a trade on the car. It sure was nice to meet you. I'll have to see what I can do when the white car sells.
» B&M finned aluminum transmision pan pics (new price $95.00 + shipping)
» 528 CI MOTOR COMPLETE new price
» Race convertor NEW PRICE
» Trade for CJ/SCJ/PI Aluminum Valve Covers M/T SBF Black Aluminum Finned
» Bruno's lenco 3 speed NEW PRICE Sold bruno still have Lenco and convertor
