Truck pan pickup tube
61coon
waypastcrazy
Truck pan pickup tube Empty Truck pan pickup tube
Post  waypastcrazy July 3rd 2013, 11:00 pm
Anyone know what part # for the replacement oil pump pickup tube of a 460 factory rear sump truck pan is?
Have surfed the internet with no results I was comfortable with.thx Clyde
waypastcrazy
waypastcrazy
Truck pan pickup tube Empty Re: Truck pan pickup tube
Post  61coon July 3rd 2013, 11:04 pm
http://www.jegs.com/i/Ford-Racing/397/M6622DRS460/10002/-1?parentProductId=1128244#moreDetails
61coon
61coon
Post  waypastcrazy July 4th 2013, 7:29 am
The pan listed for that pickup tube is a deep sump.
does not look like a stock pan to me.thx
http://www.fordracingparts.com/m/part.asp?p=13044
waypastcrazy
waypastcrazy
Post  waypastcrazy July 4th 2013, 7:33 am
I may just modify the pan to moroso specs and build a tube.Idk time if I only had more time.LOL!
waypastcrazy
waypastcrazy
Post  61coon July 4th 2013, 9:44 am
My bad Clyde. What about van oil pans aren't they rear sump as well? Seems to me your local parts store should be able to get one for ya.
61coon
61coon
Post  61coon July 4th 2013, 9:53 am
On second thought, I think the van pans might be a mid sump deal?
61coon
61coon
Post  waypastcrazy July 4th 2013, 9:59 am
I know spectra makes the pan and tube for 351w but cant find their # for the 460.
I think they are canadian based.
Vans are mid sump deal.
waypastcrazy
waypastcrazy
Post  whitefield July 4th 2013, 1:29 pm
Check these out and see if they look right!
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_oil-pump-screen-melling_19690674-p?searchTerm=oil+pump+screen
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_oil-pump-screen-sealed-power_20684076-p?searchTerm=oil+pump+screen
whitefield
whitefield
Post  waypastcrazy July 4th 2013, 2:39 pm
Pretty sure that ds2 is same thing I have tried.
May try again.I beleive someone dropped the ball on repro specs.Or parts house just has wrong part labeled.idk
I appreciate the help.
waypastcrazy
waypastcrazy
Post  Lem Evans July 4th 2013, 2:44 pm
Is this it?
http://www.autozone.com/autozone/parts/1995-Ford-F250-3-4-ton-P-U-2WD/Oil-Pump-Screen/_/N-j1zdgZ8zngq
Post  Lem Evans July 4th 2013, 2:48 pm
E350 van also.....
http://www.autozone.com/autozone/parts/Oil-Pump-Screen/_/N-8zngq
Post  waypastcrazy July 4th 2013, 8:26 pm
Ok guys the E350 and f350 call for same pick up tube but have completely different oil pans. The ds2 will fit the van pan but not the truck pan.That is why the ds2 will not work.
waypastcrazy
waypastcrazy
Post  waypastcrazy July 4th 2013, 8:31 pm
Van pan e350 http://m.autozone.com/autozone-mobile/en/parts/1992-Ford-E350-1-ton-Van/Oil-Pan/_/N-iwq6cZ8zn
z5?id=220538
Truck pan is this http://m.autozone.com/autozone-mobile/en/parts/1992-Ford-F350-1-ton-P-U-2WD/Oil-Pan/_/N-iwqk8Z8znz5
So someone messed up somewhere.
Frpp got it correct but I can not find there pickup tube/oil screen listed seperate from this kit here. http://www.fordracingparts.com/m/part.asp?p=1949
All replies and help are greatly appreciated!thx Clyde
waypastcrazy
waypastcrazy
Post  waypastcrazy July 4th 2013, 9:26 pm
Truck pan pickup tube Downloadfile truck pan
Truck pan pickup tube Downloadfile-3 van pan
Truck pan pickup tube M-6675-a460 frpp's deal
waypastcrazy
waypastcrazy
Post  69F100 July 4th 2013, 10:16 pm
Are you looking for a pick for the single sump pan with the sump close to the rear. If so I am going to start freshening up my old 460 out of the ranger tomorrow after work I will look and see if the pick has a number on it.
Post  69F100 July 4th 2013, 10:18 pm
my pan is like the 2nd pick
Post  waypastcrazy July 4th 2013, 10:26 pm
69F100 wrote:Are you looking for a pick for the single sump pan with the sump close to the rear. If so I am going to start freshening up my old 460 out of the ranger tomorrow after work I will look and see if the pick has a number on it.
Yes sir! I sure would be thankful.Just trying to figure out what to order so as to have it when I get home nxt week.
If I cant figure it out I will just build one.lol would rather be using that time installing my engin tho.thx
Ps: my pan is like the 1st pic.
waypastcrazy
waypastcrazy
Post  waypastcrazy July 4th 2013, 11:09 pm
Sealed powered is showing 2 different pu screens for same year make model and engine.
Part #22414257
Truck pan pickup tube 224-14257_ANG-1
Part # 22414230
Truck pan pickup tube 224-14230_ANG-1
waypastcrazy
waypastcrazy
Post  69F100 July 4th 2013, 11:19 pm
I think the bottom one is what I have but can't remember for sure let me check tomorrow afternoon when I get home. I will post which one it is when I get the pan off for you . I know I had to make the one for my 552 as it has a home built pan I took 2 pick ups and made it and it take some time for sure to build one with the right clearness.
Post  69F100 July 4th 2013, 11:20 pm
pm me your number and I will take a pic of it and send you tomorrow.
Post  Paul Kane July 5th 2013, 12:27 pm
waypastcrazy wrote:Ok guys the E350 and f350 call for same pick up tube but have completely different oil pans.
Not correct. Easy identificaion between the two OEM pickups in question:
F250 pan: pickup support bolts to #4 main cap bolt.
E250 pan: pickup support bolts to #3 main cap bolt.
Paul
P.S.: I'm pretty sure we have an F250 pan/pickup combo over here, if needed.
Post  waypastcrazy July 5th 2013, 4:26 pm
Thx paul I will let you know.
What I meant was the parts house has the van pu tube listed for both truck and van which is incorrect.There fore been causing my prob finding/getting the correct one.thx
waypastcrazy
waypastcrazy
Post  waypastcrazy August 4th 2013, 11:14 am
Update sealed power 224-14230 works with my pan.
thx for all replies Clyde
waypastcrazy
waypastcrazy
