Bolt to stud for pickup tube technique?
I'm a bit embarrassed to ask this, so don't flame me too badly lol. And yes, I've searched...a lot.
I'm swapping out the front sump pan, pump and pickup tube for a rear sump setup.
I found the part number I needed for the rear pickup tube stud. I still need one.
(Putting flame proof suit on)
Do I just remove the main cap bolt and replace it with the stud? Should I leave the other main cap bolt alone? Or, loosen both, replace bolt with stud, and retorque both? The later seems the most logical. I also would think the torque specs would be the same with using that particular stud?
Dang this asbestos is itchy...
Thanks in advance!
Thanks in advance!
56f100guy- Posts : 43
Re: Bolt to stud for pickup tube technique?
Give Lem a call he get you the main bolt with small stud on top
The bolt with the stud on the head is D9HZ-6345-A. My guys should have them in stock...any dealer can get them. They come in a pkg. of two but we will sell in unit of one.
56f100guy wrote:I'm a bit embarrassed to ask this, so don't flame me too badly lol. And yes, I've searched...a lot.
Thanks in advance!
Take out the original bolt and replace with studded bolt and tighten snug ... crack loose other bolt and re-torque in steps alternating between the two.
Wow, thanks you guys. Of the two people I've read -alot- about on this forum, and seem to have amazing reputations...you both responded.
I have a great deal of respect for those who take the time to help 'the little guy'. We all gotta start somewhere, but many times egos get in the way, and that's just life in general.
Thanks x1000, I appreciate it!
56f100guy wrote:Wow, thanks you guys.
You're welcome.
While I'm in there...
It's on an engine stand, upside down, and wide open...
So... I'm replacing the rear main seal while I'm at it. I believe the torque spec is (stepped up to) 105ft.lbs and is the same for the pickup stud?
I figure I'll leave the other main caps alone...correct? Aint broke, don't fix it...
EDIT - Looks like the -new- Ford Racing version is now an M-6345-A instead of D6TZ-6345-A . True?
» NEED stud for pickup tube.
» Main cap bolt with pickup tube support
» Longer main stud needed to mount oil pump pickup to.
» FOUND stock main cap bolt with stud for oil pickup no longer needed
» 4 bolt main conversion? Or 2 bolt main stud girdle?
