Longer main stud needed to mount oil pump pickup to.
Is there a particular ARP part number main stud that is long enough to mount the pickup tube to? If so, does someone know the number. I just looked in the catalog and all I see is the regular stud and one for use with the FRPP windage tray. Do I need just one of the ones that is used with the windage tray?
jbozzelle- Posts : 3705
Re: Longer main stud needed to mount oil pump pickup to.
I have one of the FoMoCo ones if you need it.
Curt- Posts : 2791
Still forgot to call you about that glide. I've been busy trying to get these parts all lined up to assemble this engine. Is the FoMoCo one a stud or bolt?
Can I even mix a stud and a bolt on the #4 cap if needed? Or would that affect the loading the cap sees and possible cause some bearing wear problems?
Yes, it is a bolt. I guess it is ok, I have ran them for years with studs.
Curt- Posts : 2791
Thanks for the offer. I got one from Lem a few minutes ago when I ordered a few other things.
» FOUND stock main cap bolt with stud for oil pickup no longer needed
» D9HZ-6345-A Main Bolt with Oil Pickup Stud
» Bolt to stud for pickup tube technique?
» Wanted A460 headers for SN95 Mustang!
» front oil pan stepped stud - longer
