front oil pan stepped stud - longer
front oil pan stepped stud - longer Empty front oil pan stepped stud - longer
Post  Kobelco January 13th 2022, 10:06 am
For replacement front covers that have 5/15 threaded holes at the ends anyone have a source where the stepped stud has 1/2" + longer 1/4 shank?
Kobelco
front oil pan stepped stud - longer Empty Re: front oil pan stepped stud - longer
Post  rmcomprandy January 13th 2022, 11:36 am
Kobelco wrote:For replacement front covers that have 5/15 threaded holes at the ends anyone have a source where the stepped stud has 1/2" + longer 1/4 shank?
Thread those corner holes for a 1/4-20 heli-coil.
Kobelco likes this post
Post  Paul Kane January 13th 2022, 3:28 pm
We have these 5/16-18 to 1/4-28 studs:
front oil pan stepped stud - longer Steppe10
front oil pan stepped stud - longer Steppe12
They are ~1.40" in overall length, and the 1/4-inch threaded section is 1.00" long.  They cannot be simply threaded in by hand and do require some effort via (for example) two nuts jammed together on the 1/4" section and then driven into the timing cover with oil and a ratchet, etc.
4 pieces $22 shipped, call directly to order
Post  gt350hr January 13th 2022, 7:08 pm
I did like Randy did and used two helicoils because I am using the factory load spreaders that are made for the 1/4" bolts.
gt350hr
