plate location on dual plane intake
I'm new to the nos world on v8 motors. Have experience on motorcycle, but none on car/truck motors so bear with me. I'm putting a NOS Cheater setup on my 466 mud truck and have a stealth intake. My machinist said the motor is good for a 250 shot, so my plan is to try it at 150 and work my way up until I get it where I want it. My big question is with the divider of the stealth, is it wise to put the spray plate all the way down on the top of the intake, or should I put a 1" spacer under it to help it mix better? The destructions that come from NOS recommend running an open single plane intake, so it has me concerened some. The motor runs great on fuel alone with an 850dp, 1" power cone spacer on top of a 1" open spacer, so I was thinking about putting the spay plate between the 2 spacers, but want to make sure that is a good idea before I do it. ANy help would be appreciated.
kjett- Posts : 1169
Re: plate location on dual plane intake
I would sure try the spacer as well.. We have used them before on similar combos and they seemed to help as well.. Thanks, Steve
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Thanks Steve, I'll try it out!
kjett- Posts : 1169
I had a stealth intake and was concerned about the sray pattern. So I set it up on the bench and sprayed some nitrous! The spray looked alright with and without a 1" spacer. I didn't shoot any gas thru it during my testing. No further details are available, as I did this about 3-4 years ago and didn't document it with pictures.
That being said, I used a spacer when it was installed on the car.
the1969fordguyinky- Posts : 237
you are going to need more than 150 to keep up with me
IcallhimGeorge- BBF CONTRIBUTOR
IcallhimGeorge wrote:you are going to need more than 150 to keep up with me
Ha, to keep up with you all I need it this:
http://www.google.com/products?hl=en&source=hp&q=nos+energy+drink&um=1&ie=UTF-8&ei=eAznSr-oDM7hlAf-xYX8Bw&sa=X&oi=product_result_group&ct=image&resnum=4&ved=0CCoQzAMwAw
kjett- Posts : 1169
you mean like this?
bring it on big daddy!
Yep. I proved my 150 is close, but I KNOW the ranger is faster!!
kjett- Posts : 1169
wouldnt be the first time I lost a race.
Yep, it's all good as long as you have cold beer, ice, a piece of 1/2" aluminum fuel line, an air compressor, and a few bottles of home brew wine!
kjett- Posts : 1169
5/8" fuel line....
and I dont think this site is ready for such shenanigans
I bet they are!
kjett- Posts : 1169
» dual plane intake for 557
» 302 dual plane intake
» WANTED DUAL PLANE INTAKE 429 460
» Question on a dual plane intake on a 557
» WTB 400 4 bl intake , dual plane. Found thanks
