8.208 @ 165 P-51 Headed Monster
+13
BradB
56Tbird
hienergy557
KY JELLY
RapidRuss
deliveredfast
Old blue Racin Team
17 posters
8.208 @ 165      P-51 Headed Monster Empty 8.208 @ 165 P-51 Headed Monster
Post  bruno August 8th 2009, 9:59 pm
KY Jelly's recent pass ....with very old tires and a fat tune up ...this is all motor guys ......nasty
8.208 @ 165      P-51 Headed Monster Th_09080201
http://WWW.CKRME.COM
8.208 @ 165      P-51 Headed Monster Empty Re: 8.208 @ 165 P-51 Headed Monster
Post  69F100 August 9th 2009, 5:35 pm
that is moving
Post  Old blue Racin Team August 9th 2009, 5:48 pm
Hes Haulin
Old blue Racin Team
Old blue Racin Team
Post  deliveredfast August 10th 2009, 12:09 am
hi guys, how much does the car weigh? that thing is flying.
deliveredfast
deliveredfast
Post  IDT-572 August 10th 2009, 12:11 am
That's not all it has, I am sure there is more to come. Cool
Post  Nevs August 10th 2009, 12:56 am
deliveredfast wrote:hi guys, how much does the car weigh? that thing is flying.
I believe Randy said it weighs around 2400#. Very impressive performance Exclamation
Post  c.evans August 10th 2009, 1:41 am
If you listen at the end of that video, you can hear the crowd cheering about the numbers he put up on the board. Later on, one of the girls that was there came over and wanted to take Randy's, and the car's picture, because as she said; "he was the fastest racer here". I chuckled.
His 1/8th mile e.t. was 5.23 on that run I believe, however he has run a couple of 5.15 e.t.s at Beech Bend. At the end of the day, that's not bad for a 562 CID engine with a set of OEM style heads,,,,meaning the P-51 heads.
Meanwhile, Randy's new nickname is "The Velcro Kid".
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  RapidRuss August 10th 2009, 8:05 am
DAMN !!! That's quick !! Go Get um Randy !! Looks Like Mr. Hobbs is gonna have to step it up a notch or 2 !
RapidRuss
RapidRuss
Post  dfree383 August 10th 2009, 8:25 am
I'm guessing he got the velcro corretcly "engineered" on that run? LOL
Goooooooo Velcro !!!
Post  KY JELLY August 10th 2009, 12:03 pm
Thanks guys here is a pic taken by indie images of the first pass with this engine before some suspension de - tuning affraid
8.208 @ 165      P-51 Headed Monster 515
KY JELLY
KY JELLY
Post  IDT-572 August 10th 2009, 12:05 pm
Should have left it alone , I like that look. Cool Laughing Razz
Post  KY JELLY August 10th 2009, 12:12 pm
This is for you defree see the hi tec velcro safety strap on the fuel shut off its not latched lol!
8.208 @ 165      P-51 Headed Monster DSCF3537
KY JELLY
KY JELLY
Post  hienergy557 August 20th 2009, 6:22 pm
Hey Randy,
What did you do to tame that wheelstand? Move the I.C.
It looked impressive.
Cheers Colin.
hienergy557
hienergy557
Post  KY JELLY August 20th 2009, 10:41 pm
Thanks Colin,
I tightened the extension on the shocks while I was there (when the pic was taken) it helped quite a bit, but I eventually moved the 4 link down a hole at the housing on the top bar later on .
I was not ready for a wheel stand like that the first pass so I was a bit concerned affraid .
A couple of weekends later at the bash the car layed down 3 1.09 60 times, several 1.10's and a 1.11.
After about 30 passes I am suspecting the sidewalls gave up on the tires and it started the spinning. I am too poor to be buying tires every 30 passes so I am just letting it spin until better weather rolls around Laughing .
I am going to switch to a d-5 from the d-6 compound and see how that works out.
KY JELLY
KY JELLY
Post  hienergy557 August 20th 2009, 11:32 pm
KY JELLY wrote:Thanks Colin,
So Randy,
It looks like you moved your I.C forward and higher to tame it down, is that correct?
You are making more power than me but I can see some similarities with my set-up.
Just trying to understand what you did because it seemed to work.
Do you know what distance out and height your I.C was, and what it is now after the change.
Cheers Colin.
hienergy557
hienergy557
Post  KY JELLY August 21st 2009, 10:04 am
The original ic setting was 49.3" @ 5.7" high , it is now at 60.9 @ 5" high.
I moved it down a hole in the rear to try and take away some of the instantaneous "hit" and apply more leverage as it moves out. In theory this is supposed to allow a little tire slippage and then hook it up as it moves out.
The top bar is pulling and the closer the top bar is to the housing the speed of the movement is slowed down due to a leverage disadvantage at the housing brackets. At the same time it puts the bar at a flatter angle to the chassis allowing for a slower more controlled and powerful application of the leverage to go along with increased engine hp/tq. You can't move one end of the bar without effecting the other so it all works together to some point.
I am not a chassis expert , but I have formed some opinions messing with mine and it may not agree with what some people say or believe.
I think the term ic is really meaningless on a 4 link , its just a reference point, its where your pivot point is on a ladder bar so it means more in that situation .
I know everything thing you read points at the imaginary intersect point (ic) , but the truth is that could be the exact same with 2 or more different 4 link settings if the brackets allowed it. How could that act the same way with different bar spreads ? The bars are pulling and pushing at the brackets not the imaginary intersect point.
I still measure and reference the ic , but just to keep tabs on what it does when I move the 4 link. The more I move it the less faith I have in the outward measurement of ic , I think the height is the most important and its a direct result of the top bar placement and the bottom bar angle. In most cases when you get the bottom bar right for the chassis in general you are not going to move it unless the power is really increased and then more than likely it would be done with a ride height change.
KY JELLY
KY JELLY
Post  56Tbird August 21st 2009, 10:24 am
RapidRuss wrote:DAMN !!! That's quick !! Go Get um Randy !! Looks Like Mr. Hobbs is gonna have to step it up a notch or 2 !
Russ , I'm about $20,000 or so away from being able to compete with this bad boy!! I can't say it won't ever happen...but it ain't lookin good right now affraid drunken lol!
56Tbird
56Tbird
Post  hienergy557 August 23rd 2009, 6:13 pm
Thanks Randy, good info.
Cheers Colin.
hienergy557
hienergy557
Post  RapidRuss September 25th 2009, 9:58 am
Well Dan..i dont know about you being $20K away as your Hotrod gets ur dun too.. But i was just so suprised at it being P-51 headed and with the 1.09 60 footers.. at a buck 65.. and there's more in it !! Damn Exclamation
I'am just glad he still lets us talk to him Exclamation Exclamation affraid lol!
RapidRuss
RapidRuss
Post  KY JELLY September 25th 2009, 12:46 pm
just to up date you guys due to my stupidity and hard headiness lol! This run was made with a 100% no doubt leaking head gasket .
KY JELLY
KY JELLY
Post  Nevs September 25th 2009, 2:11 pm
KY JELLY wrote:just to up date you guys due to my stupidity and hard headiness lol! This run was made with a 100% no doubt leaking head gasket .
Even more impressive. That car is a 60 footing b*itch! I'm jealous! Cool Wink
Post  56Tbird September 25th 2009, 4:25 pm
It does leave hard ,but tends to slow down very quickly when it gets close to the wall or even when it bounces off it affraid Wait till he gets er sealed up!! Cool Very Happy He scares me shitless just watching him drunken drunken
56Tbird
56Tbird
Post  BradB October 4th 2009, 3:31 pm
KY JELLY,
Do your homebuilt headers have a BBF flange on them or is it a BBC flange with adapters? Thanks
BradB
Post  Lem Evans October 4th 2009, 3:34 pm
They have a BBF flange .
Post  BradB October 4th 2009, 6:43 pm
Thanks Lem.
In case you were wondering I'm the same Brad B who ordered the p51s from you last week, I recieved them on friday. Those are nice lookin units Very Happy
On the other forum I am "hookedonpullin", but ya know what, thats to much to type. Laughing
BradB
