E3TA-6380=AA flywheel
E3TA-6380=AA flywheel Empty E3TA-6380=AA flywheel
Post  IDT-572 July 19th 2013, 11:08 am
E3 flywheel and a D1 block engine with a non hatchet weight no good............ ?
I feel a slight vibration but the E 3 fly wheel should be an external balance and out of balance ?
E3TA-6380=AA flywheel Empty Re: E3TA-6380=AA flywheel
Post  rmcomprandy July 19th 2013, 11:14 am
IDT-572 wrote:E3 flywheel and a D1 block engine with a non hatchet weight no good............ ?
An 83 flywheel sure is for an externally balanced engine unless the balancing of that engine has been modified inside.
Post  IDT-572 July 19th 2013, 11:17 am
Randy it has about 8 to 10 3/4 inch holes drilled along the outside edge on the back of the flywheel. I'm sure its not zero.
I am going to spin it up and check the balance.
Post  LivermoreDave July 20th 2013, 10:41 am
I'm not sure of the relationship the block and E3 crankshaft have as to vibration .. Very Happy  .. but somewhere along the line the E3 crankshaft may employ smaller diameter counterweights. Could that effect the balance of the rotating assembly as you mention?
Dave.
LivermoreDave
Post  IDT-572 July 20th 2013, 10:59 am
It's a D1 block and crank ie internal balance no hatchet spacer in front, and the original flywheel for the 84 truck.
Post  cool40 July 20th 2013, 12:21 pm
you need a flywheel. Suspect
Post  IDT-572 July 21st 2013, 1:27 am
cool40 wrote:you need a flywheel. Suspect
I have one it's just a 28 oz. inch deal.
