Crank pulley for racing alternator
Mark Laczo
BigRigTech
Does anyone here sell an undersize aluminum crank pulley to run an alternator on a track only car? I want to install one on my car. V-groove is what I'm looking for, I have to adapt a mount for my front plate.
BigRigTech- Posts : 763
Re: Crank pulley for racing alternator
BigRigTech wrote:Does anyone here sell an undersize aluminum crank pulley to run an alternator on a track only car? I want to install one on my car. V-groove is what I'm looking for, I have to adapt a mount for my front plate.
What damper?
I have an ATI damper. It uses a 3 bolt BBC front pulley bolt pattern. I use a 5" pulley from East Coast Auto Electric:
http://www.ecae.com/brackets.html
bottom of that page
If you have a damper with a Ford bolt pattern you can get one from DSC Motorsports
http://www.dscmotorsport.com/Crankshafts/index.htm
a pic of it on a friends BBF dragster:
PRW 4 bolt balancer.
Pulleys
I am going to try one from these guys.
http://www.cvfracing.com/ford-pulleys-s/33.htm?gclid=CLbPvfvM2rgCFfFDMgodRSsAdA
FWIW Mark
FWIW Mark
Mark Laczo- Posts : 274
March make some for a BBF
I just recently bought a billet, 4 bolt Ford, deep groove, 4" O.D. crankshaft pulley from MOROSO #64551. It has an offset and is not flat.
Glad someone asked the question I was gonna buy the March pulley but at $97.99 the CVF and DSC look like a way better price.
Mark Laczo wrote:I am going to try one from these guys.
FWIW Mark
X2 I've been looking at these for sometime
1faststang- Posts : 129
I have personally witnessed how ineffective an alternator is when "slowed down" by the addition of a larger diameter alternator pulley. On applications with extended high RPM operation a larger pulley may provide extended service to an alternator. On a drag race application, slowing the alternator (at most Bracket Race levels) will not provide sufficient voltage/charging to the system.
Dave.
http://www.stockcarracing.com/tipstricks/scrp_0506_racecar_alternators_debate/
Dave.
LivermoreDave- Posts : 972
I was going to run a stock pulley on the alternator, just an undersize on the crank to reduce the speed a bit.
» crank pulley and alternator/fan/pulley options?
» one wire 100 amp alternator with bracket & crank pulley
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» Billit alternator fan and pulley
» anyone use the March of CVF tall alternator pulley?
