Idt premier block ?
jason
Idt premier block ?
What bore size does the block start out? I want the strength but don't want to go over 521 cubes.
jason- Posts : 220
Re: Idt premier block ?
4.500.............
Thanks! I couldn't find anything but what it could be opened up to .
jason- Posts : 220
It must need to be sleeved down then to make a 521?
jason- Posts : 220
4.5x 4.1 would get you there.
I'm thinking about a single turbo and doing what the Chevy guys are doing with twins around here.
jason- Posts : 220
The upper-level Eliminator blocks would need to be sleeved down technically speaking, but I think the Eliminator Sportsman block will accomodate a +0.030" 521 stroker kit. So will the standard A460 block.jason wrote:It must need to be sleeved down then to make a 521?
Paul
Or just don't use a standard kit, if 521 or less is the goal, the 4.5" bore with a stock 3.85 stroke crank is going to put you at 490 cu in, or you could go with a 4" stroke and be right at 521. Big bore is going to let you use big heads, and short stroke will let you RPM the bejeasus out of it if you want.
I built a 4.630" bore 3.9" stroke, likes RPM.
kim- Posts : 700
I have an a460 block in the car now but it's a 572. My cars weighs 3500#. I would hope a 521 with a 106 mm will get it into the 7's.if it revs. Easier will it spool up quicker?
jason- Posts : 220
Spool speed is a function of turbo build, but something that RPMS well plays well with turbo applications.
Punch the A460 block out to max bore. Mine went 4.630 with no sleeve. Then go with the shorter stroke crank..... The A460 block is 18 head bolt compatable. No reason to go to the other block unless there is something hurt in yours.
kim- Posts : 700
I'm planning on putting the 572 in my 68 dodge dart. So I'd be starting over with the mustang. I just started the build on the dart last week. So I figure go with the strongest block if I'm gonna start over.
jason- Posts : 220
That ought to fire up the local "Mopar or No Car" guys! I'd put a set of Kaase Boss heads on it with plain valve covers and let the Mopar guys try to figure out what kind of Hemi is it?jason wrote:I'm planning on putting the 572 in my 68 dodge dart. So I'd be starting over with the mustang. I just started the build on the dart last week. So I figure go with the strongest block if I'm gonna start over.
Gary
GTmustang- BBF CONTRIBUTOR
GTmustang wrote:That ought to fire up the local "Mopar or No Car" guys! I'd put a set of Kaase Boss heads on it with plain valve covers and let the Mopar guys try to figure out what kind of Hemi is it?jason wrote:I'm planning on putting the 572 in my 68 dodge dart. So I'd be starting over with the mustang. I just started the build on the dart last week. So I figure go with the strongest block if I'm gonna start over.
Gary
Yeah the few mopar guys around here that know about it are pissed. It's funny ya bring up boss 9 heads, I was on the kasse web site thinking the same thing.GTmustang wrote:That ought to fire up the local "Mopar or No Car" guys! I'd put a set of Kaase Boss heads on it with plain valve covers and let the Mopar guys try to figure out what kind of Hemi is it?jason wrote:I'm planning on putting the 572 in my 68 dodge dart. So I'd be starting over with the mustang. I just started the build on the dart last week. So I figure go with the strongest block if I'm gonna start over.
Gary
jason- Posts : 220
Tell the Mopar guys not to sweat it. Chrysler Marine was using 460s in there marine applications in the late 80s! That makes it okay doesn't it?
Bret Powell- Posts : 133
No problem, there are 2 cars with 400ci SB 106 w/ 1.0 ar exhaust housing 3300# running 7.7s up here at bandimere 6000'. No issues with spooling.jason wrote:I have an a460 block in the car now but it's a 572. My cars weighs 3500#. I would hope a 521 with a 106 mm will get it into the 7's.if it revs. Easier will it spool up quicker?
mico- Posts : 33
» Need Eliminator Premier Block / BLOCK FOUND!!!!!
» Cracked Premier IDT Eliminator Block
» 4.75 stroke in Eliminator Premier Block
» A-460 or Eliminator Premier block
» IDT Eliminator Premier Block For Sale
