4.75 stroke in Eliminator Premier Block
powerstrokeace
fatal addiction
4.75 stroke in Eliminator Premier Block Empty 4.75 stroke in Eliminator Premier Block
Post  Doug Rahn March 2nd 2011, 7:19 pm
Has anyone done it yet? What issues if you have?
4.75 stroke in Eliminator Premier Block Empty Re: 4.75 stroke in Eliminator Premier Block
Post  fatal addiction March 2nd 2011, 7:32 pm
lots of people do it
fatal addiction
fatal addiction
Post  c.evans March 2nd 2011, 10:28 pm
Check the clearance of the skirt of the piston at the bottom of the cylinder, when the piston is pulled all the way down. In other words piston skirt to main web clearance.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  powerstrokeace March 23rd 2013, 5:18 pm
can this work in A460 blocks as well. What's the largest stroke for a DOVE block
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans March 23rd 2013, 5:48 pm
powerstrokeace wrote:can this work in A460 blocks as well. What's the largest stroke for a DOVE block
Ace
The cyl. walls are not as long on the D0VE blocks as they are on the D9 & A460 blocks.....D0VE block would not be the preferred canidate for a 4.750" stroke.
Post  Barney March 23rd 2013, 6:14 pm
Piston side load I'd the msin idsue with any short deck block with that much stroke.
Barney
Barney
Post  Barney March 23rd 2013, 6:16 pm
Auto correct ughhh
Barney
Barney
Post  Curt March 23rd 2013, 6:23 pm
Barney wrote:Auto correct ugh
Laughing Not hardly Laughing
Post  Wheelie58 March 24th 2013, 12:41 am
Doug Rahn wrote:Has anyone done it yet? What issues if you have?
Doug,
With Oliver steel rods, it takes a slight relief at the bottom of the bore that can be easily done by hand. There is also a few areas at the pan rail that need hand work. With aluminum rods, it is nicer to do the clearancing in a mill, but it is not extreme. ESI has several 632/638/652 shop engines out there with 4-3/4" arms.
Keith
Wheelie58
Wheelie58
