a460 v/s Eliminator premier block
+11
kim
QtrWarrior
460bronco
DanH
MustangDan
15 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Ok witch block is a better block and why or they basically the same. I do no about the cap difference on the premier block being all four bolt main and you can get them In billit caps .what you guy think ...... thanks
MustangDan- Posts : 140
Re: a460 v/s Eliminator premier block
Either one is a great foundation, and will do what ever you need. The Eliminator is a little more money, and you may have to wait on availability. The A460 is almost always ready to ship.
schmitty- Posts : 4538
is one stronger than the other I really don't think so
The eliminator blocks do offer a lot of nice options and billet caps on some models, but they are more expensive and typically can have a long wait to get one.
The a460 blocks are plenty good too.
Not really.MustangDan wrote:is one stronger than the other I really don't think so
.MustangDan wrote:Ok witch block is a better block and why or they basically the same. I do no about the cap difference on the premier block being all four bolt main and you can get them In billit caps .what you guy think ...... thanks
depends on your final build . you want roller cam bearings? extra cost for the A460 block for one example
DanH- Posts : 1081
My friend has Eliminator premieres in stock ill shoting for 1500hp and more soon
Does anybody know the general max safe bore size for A-460 vs. eliminator premier?
460bronco- Posts : 364
[quote="MustangDan"]My friend has Eliminator premieres in stock ill shoting for 1500hp and more soon[/quote
you should be asking your friend about the blocks,
DanH- Posts : 1081
Finding a ring pack above 4.650 bore is going to be expensive, and most A and Elim blocks will go that far.
The max safe bore on an a460 is 4.600, but most will go over that.
As far as eliminator blocks it depends on the model, they offer some that are not good for more than 4.500 and some that can go to 4.700
DanH what u mean the a460 r rated more then 1500 anyway and a stock block goo to 1000 and be very safe and from my knowledge the only difference between the two blocks are the caps
Stock blocks will not go safely to 1000hp they are a bomb fuse at that level
The stock blocks and an a460 block are not alike. The a460 stuff is much thicker and heavier.
MustangDan wrote:My friend has Eliminator premieres in stock ill shoting for 1500hp and more soon
IF your friend has them in stock, then it should have been an easy choice...
QtrWarrior- Posts : 2702
Dfree I no stocks not the same as a a460.a460 and premier was the ones I was talking about I no people make over 1000on stock 460 for years if a winsor can go 800and be ssfe Y couldnt a 460go to 1000 :-/
I know there were guys back in the day going over 1000hp with boosted deals, and they were living, just not very long.
some people cam blow shit up well under four digit horsepower the block not being the factor........just sayin'........
Yeah a good tune helps I here 1800 on the a460 and 2500 on the eliminator I was making 650 hp on a stock 302 took it apart and all looks good
MustangDan wrote:Yeah a good tune helps I here 1800 on the a460 and 2500 on the eliminator I was making 650 hp on a stock 302 took it apart and all looks good
What kind of use did that 302 see?
If that was a documented 650 hp in a stock 302 block, I'd have expected it to split in two on the second dyno pull.
maverick- BBF CONTRIBUTOR
Nah... 640hp on a daily streeted 302. It lasted about 3 years. Didn't split in 2, blew a cylinder apart, cracked vertically bottom to top at the 4 corners. 69 block.... Most of the time it was street driven and only run up to about 5k At the track on slicks it did 5k clutch drops and shifted about 7500RPM. Now the T5... that didn't fare so well.
kim- Posts : 700
Most drag and a friend had a 9.40 302 for 3 years and still doing great so that's y I'm sure a 460 will do 1000 with no problem
Keep it under 6500 and its fine
You build a lot of big engines?
This is my first bbf but my father inlaw doseand a few of my friends do
The Eliminator premier block I can get for just a few hundred more than a 460 and it has billet caps
Do u guy think its worth 300 more then a460 ... thanks for your help
Page 1 of 2 • 1, 2
» 4.75 stroke in Eliminator Premier Block
» Need Eliminator Premier Block / BLOCK FOUND!!!!!
» Cracked Premier IDT Eliminator Block
» A-460 or Eliminator Premier block
» WTB eliminator premier block
Page 1 of 2
