Rev Kit springs
Rev Kit springs
Last edited by JBR-3 on February 22nd 2020, 1:48 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Rev Kit springs
The CompCams springs for a small block Chevy rev kit are inner valve springs #974, (the pale blue ones).. They have 96 lb/in of rate, about 40/45 pounds @1.500" installed.JBR-3 wrote:I'm not aware of any available rev kits for any Ford, but I'm curious about
the specs for a rev kit spring, likely for a Chev application.
I.E., what would be spring rate and installed height ?
On engines that use a rev kit, are the valve springs then somewhat
reduced in pressure ?
Considering possibly fabbing up a deal for the BBF.
Re: Rev Kit springs
Last edited by JBR-3 on February 22nd 2020, 1:49 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
» Comp Cams valve springs
» 55 staight axle swap 02 ranger ifs donor truck
» CAM vs SPRINGS
» Help on springs
» valve springs for roller cam
» CAM vs SPRINGS
» Help on springs
