Head ports look damaged, OK or bad?
Head ports look damaged, OK or bad? Empty Head ports look damaged, OK or bad?
Post  racinghabbit August 14th 2013, 12:13 pm
I have a set of DOVE-C heads  max effort....
I took a head off the other day and noticed that on the to of 3 of the Exhaust ports there are small holes threw the casting.out by where the header bolts on.( about 3/4 of an inch in from where the header bolts on) I have no idea how long its been like this..
WIll it hurt anything?
Is it bad?
It runs great...
racinghabbit
racinghabbit
Head ports look damaged, OK or bad? Empty Re: Head ports look damaged, OK or bad?
Post  dfree383 August 14th 2013, 12:45 pm
Is it just broke thru into the head bolt holes? That not an Issue.
Post  racinghabbit August 14th 2013, 1:15 pm
its at the very top of the port... just threw the internal casting
racinghabbit
racinghabbit
Post  dfree383 August 14th 2013, 1:31 pm
Sounds like a break thru into the thermactor port... not a big deal either.
You can shove a rod down the port from the end of the head if the hole bothers you or even braze them.
Post  racinghabbit August 15th 2013, 2:57 pm
Good news then!! They don't bother me... LOL What a Face
racinghabbit
racinghabbit
